By Inches Tactics Card
Discussion in 'Rules' started by oberwald, Dec 20, 2020.
  1. oberwald
    oberwald Active Member
    I was wondering if the Sterling Forge Tactics Card "By Inches" can be applied to movement.
    The text says: "This Action hast its Maximum Range increased by 1 or has its Minimum Range decreased by 1".
    Movement is a type of action but one could argue movement doesn't have a range necessarily.
    That's why I'd interpret the card as not applicable to movement.
    Any thoughts?
  2. ZombieSashimi
    ZombieSashimi Well-Known Member
    I think you are right in your assumption. Range is marked on all actions that use it and movement does not have a range.
  3. tox
    Range is always displayed with :L: (LoF) or :SL:(No LoF).
    Movement does not have a range
    AdmiralJCJF and ZombieSashimi like this.
  4. oberwald
    Thanks for the help guys.
    Glad we all concur.
  5. Ealthril
    Ealthril Well-Known Member
    Movement is an action that grants you movement points, this is why it has no range. You "gain" as X movement points as your X personal value indicated on your Character card.
