Blue Wolf
Discussion in 'Yu Jing' started by Triumph, Aug 7, 2020.
  1. Janzerker
    Janzerker Well-Known Member
    Actually I wouldn't even bother about the Blue Wolf if it wasn't for Multiterrain (in addition to full auto).
    That's what I wrote ;)
    As to your later question, I have no fkin clue what might be fair. Mostly I'd like it to cost sufficiently low that a duo is possible without sacrificing the rest of the list.
    I do think there will be some differences though. Mainly in the PH for Gizmo and Dodge.
  3. Space Ranger
    Of course he looks cool but I probably still wont take him. That many more points for CC is just dumb. A stat that that's used maybe once in a 50 games with him. Full Auto (assuming it's stays) is good but then he's just a glass canon. He can dish it out but can't take it.
  4. Death
    Death Well-Known Member
    Actually, I wonder how much that dodge: PH = 11 reduces the cost of the Haqq TAG. It could be by A LOT given that we know PH reduced HI save a lot of points.
    Savnock likes this.
  5. Someone
    Someone Active Member
    If the Dodge -6 for TAGs is still the standard then that PHY=11 is a good Dodge stat for a TAG
    the huanglong likes this.
  6. Mahtamori
    Universal -6 Dodge seems to be gone for TAGs, replaced by a specific value in their profiles.
    Savnock likes this.
  7. Someone
    Which seems much simpler. The new arrangements so far seem much more straightforward.
  8. Mahtamori
    Kind of, but it does make the special rules row a bit crowded on some units. Maybe they should consider making a modifiers row and a separate special skills row.
    Savnock likes this.
  9. Someone
    There maybe a better arrangement but so far I am happy with that part of this. Maybe it will turn into a mess but I hope not.
    Mahtamori likes this.
  10. Brokenwolf
  11. Miraclebutt
    Miraclebutt Well-Known Member
    PH=11 is before mods are calculated, so the Blue Wolf might just have PH15 as a baseline instead of hyperdynamics and PH=12 or whatever.
    The modified Gizmokit PH stat is something every TAG gets on their profile, as Gizmokits are rolled off PH and can be used when damaged, not just when unconscious.
    This TAG is pretty amazing though. I can see it dropping down to low-mid 70s and being a viable contender for a list.
    #51 Miraclebutt, Aug 14, 2020
    SKOZZOKONZ likes this.
  12. Triumph
    Did they mention if it hurts on a fail like engineering does in N3?
  13. colbrook
    Engineering inflicts a wound on a fail in Code One, so chances are high.
  14. Miraclebutt
    Yes, confirmed in the seminar stream.
  15. Mahtamori
    From the stream at roughly 2:08:30
    Q: does gizmokit kill unit on fail
    A: yes, when on last wound
  16. Triumph
    Hmm, less exciting then. Still probably going to stay measure of last resort trying to heal manned tags with an engineer.
  17. Benkei
    Benkei Well-Known Member
    Low 70s I would consider it, yes
  18. Mahtamori
    Looking at CodeOne Gamma at 50 to 55 points (translated), I'd say that 70's isn't unreasonable, which would also put the combined CC values, burst, and increased dodge ability at about 15 points compared to the HB TAG, which I feel isn't unreasonable.
    I do think that the Guijia shouldn't be far behind the BlueWolf, though, and I don't think low 70s is entirely likely unfortunately.
  19. colbrook
    Increased speed too, the Haqq TAG is only 6-2, no faster than an ORC trooper.
  20. Mahtamori
    Ah, I missed that. I don't think that's very huge, but I do recognise that it does affect points.
