Axl Switch
Discussion in 'Rules' started by SushiYumYumz, Jul 16, 2019.
  1. SushiYumYumz
    SushiYumYumz Member
    The way this reads Axl can displace Around a target, and once away from the target at maximum until he is no longer adjacent correct?
    So this would allow him to loop around the target and then displace away one space.
    Not displace as far as he would like?
    @-V-
    AdmiralJCJF likes this.
  2. zephen1802
    zephen1802 Active Member
    Correct, you have to resolve a use of a switch before resolving another (or the same one again). So as soon as he isn't adjacent, you couldn't trigger his general switch again
    AdmiralJCJF and SushiYumYumz like this.
  3. SushiYumYumz
    SushiYumYumz Member
    perfect, this was my understanding aswell, But wanted to get this up before There is a question with no FAQ for it.
  4. AdmiralJCJF
    Yeah, I don't think there's any disagreement over this, but I can see it coming up as a question.
  5. tox
    I beg to disagree...
    The generic switch take place in the Switch Step
    The Automatik Skill Footwork take place in the Result Step
    1. Tactics.
    2. Roll the dice.
    3. Critical Block.
    4. Switches.
    5. Results.
  6. AdmiralJCJF
    We aren't discussing Footwork.
    We are ONLY discussing the Generic Switch.
    WITH Footwork AS WELL then you CAN end up as much as 3 hexes in total away from your Target.
  7. tox
    Ah, ok! I misuderstood for the overlapping of the two effects!
  8. -V-
    -V- A! Team member
    It's correct.
    :wink:
  9. konuhageruke
    Footwork
    In Disengagement roll, you usually look at cancelling active players:2: with reactive :1: since the other way around has no effect.
    Can I displace with AXL if I roll :1: in disengagement roll as active and oponent has :2: in his roll?
  10. -V-
    -V- A! Team member
    Disengagement is a Face to Face Roll. If you nullify one :2: with one :1: you may Displace yourself (up to twice per Roll). It could happen that you fail to get disengaged but succesully displaced.
    Axl is pretty difficult to get trapped!
    :wink:
  11. konuhageruke
    ok. That is pretty strong.
  12. AdmiralJCJF
    And you could also Displace with a :3:first.
  13. -V-
    -V- A! Team member
    Yep. And this is why Axl may be a scorer.
    Croepoek likes this.
