Armour Penetrating Kokram: Working with the Guijia+Krit duo (vanilla & IA)
Discussion in 'Yu Jing' started by Weathercock, Sep 8, 2019.
  1. zapp
    zapp Well-Known Member
    I'll try it out again. It always depends on the mission. My plan is to have it together with the Mowang in a vanilla list for that 3 extra orders around the KuangShi. If that mission has a Datatracker order like Countermeasures, its a minimum of 14 orders in LI or even more if you have two groups.
  2. Azuset
    Azuset Well-Known Member
    Table layout matters too imo.
  3. Barrogh
    Barrogh Well-Known Member
    It's a bit off topic, but unless something has changed, it doesn't have DAM 15 HF because only weapons that roll to hit are affected by Fat1.
    Mahtamori and csjarrat like this.
  4. Azuset
    Thanks for pointing that out. :)
  5. Savnock
    Savnock Nerfherder
    A TAG is a TAG, and having a TAG that can haul a very durable Engineer around with it is good, even at cost.
    Like @Janzerker , I would (and will) run it surrounded by chain chaff. Two groups with the TAG in one and some ablative terror-troops in the other would work well. And when you field chain-chaff, a Rui Shi to back them up is a good thing.
    I also love some Sat-Lock for sussing out camo troops in a way that really threatens them. Either an LGL or a Krakot with grenades is a good cheapo just-in-case tool for that. TAGs can make good bait, and then you use the other group with the chainrifles and visor to go sweep the opposing skirmishers away.
    You'll probably want to save your tokens with a list like this for creating links when you drop TeamPro to throw on Assisted Fire and then need to switch back... or just use the Duo one time and then ditch it.
    Yu Jing
    GROUP 1[​IMG] [​IMG] [​IMG]8
    GŪIJIĂ MULTI HMG, Heavy Flamethrower / DA CCW. (2 | 88)
    [​IMG] GŪIJIĂ PILOT Light Flamethrower / Pistol, Knife. ()
    KOKRAM FTO (Fireteam: Duo) Combi Rifle + E/Mitter, Chain-colt, E/Mauler / 2 Heavy Pistols, Knife. (0 | 39)
    WÈIBĪNG Yaókòng Combi Rifle, Sniffer / Electric Pulse. (0 | 16)
    ZHANSHI Combi Rifle + Light Grenade Launcher / Pistol, Knife. (1 | 15)
    ZHANSHI Lieutenant Combi Rifle / Pistol, Knife. (0 | 11)
    PANGGULING Hacker (EVO Hacking Device) Electric Pulse. (0.5 | 25)
    GROUP 2[​IMG] [​IMG] [​IMG]6 [​IMG]2 [​IMG]5
    NINJA Hacker (Killer Hacking Device) Tactical Bow / Pistol, DA CCW, Knife. (0 | 29)
    CELESTIAL GUARD (Kuang Shi Control Device) Combi Rifle + Light Smoke Grenade Launcher / Pistol, Knife. (0.5 | 13)
    KUANG SHI Chain Rifle / Pistol, Knife. (0 | 5)
    SHAOLIN Chain Rifle, Smoke Grenades / Pistol, Shock CCW. (0 | 5)
    5 SWC | 300 Points
    Azuset likes this.
