ALEPH questions
Discussion in '[Archived]: N3 Rules' started by Keyrott, Nov 15, 2018.
  1. Keyrott
    Keyrott Nomad Handyman
    Couple ALEPH specific questions:
    So Jumper Lv: Z affects every REM unit within a remote fireteam with the active marker at the same time, because they're all being granted Number 2 while the marker is active on them. IE you can't have a Jumper Lv: Z marker on a Dakini Fireteam, be using the Cyberdancer's stats on one dakini and have another "elect" not to be affected by the marker on his fireteam and buff him seperately with Marksmanship. That's not legal, correct?
    Also, when you have two Posthuman proxies that deal with advanced deployment or infiltration and there's a rule that hinders deployment like Biotechvore, since they're all just a single trooper they all only have to make one "Confused Deployment" roll correct?
    Thanks in advance
    JumperZ: The exception to Supportware is written on a per-Trooper basis. As I read it, putting Assisted Fire on one of the Dakini should still allow you to elect to not have that Dakini be affected by JumperZ while the other Dakini are. However, since it's the Fireteam that triggers the JumperZ Trooper to be activated and not the individual Trooper, as I read it you can not use Assisted Fire (etc) to avoid having the JumperZ trooper activate due to ARO activation on the Dakini.
    Confused Proxies: Proxies are considered a single trooper for list building/combat group only. They are still two or three separate troopers and will roll the modified PH roll for Confused Deployment separately.
    Keyrott, DukeofEarl and eciu like this.
