AI Beacon and Biotechvore
Discussion in '[Archived]: N3 Rules' started by Nemo No Name, Apr 26, 2019.
  1. Mahtamori
    The rules say no such thing. They say AI Beacon must deploying using Combat Jump, specifically not "as if they were a trooper". Deploying using the rules for Combat Jump works without your assumption.
    This is a valid point, and it should really not be buried in the traits page. My god, how blasting annoying it is to find that crucial information there.
    toadchild likes this.
  2. Robock
    Robock Well-Known Member
    They either deploy "as if they were a trooper", or "as if they weren't a trooper". (in addition to deploying as if it wasn't a hellcat, as if it was an equipment, etc, one does not exclude the other. But on the trooper/non-trooper boolean it has to fall in either side.)
    If they deploy as if they weren't a trooper, then you'll have a hard to time to deploy them following all the trooper related rules of that special skill. So it is safe to assume they mean use that trooper-exclusive skill as if you were a trooper.
  3. Hecaton
    So you'd make the argument that a Disconnected CrazyKoala can still Boost?
  4. Mahtamori
    I'm sorry, but I don't agree, they deploy using the Combat Jump rules, brute forcing past the first bullet point using the AI Beacon rule. As if or as if not trooper isn't written anywhere and is not necessary if you read the rule with "trooper" being a reference to the first instance "trooper" that the AI Beacon rule brute forces past instead of a formal rules term. There are potential other effects coming from "as if a trooper" that might cause problems, so I prefer not to make up rules in order to get the machinery running smoother. What speaks against you the most here is the answer given when they first answered whether AI Beacons received the bonus from EVO Hacking Devices; "no, they are not troopers".
    (This is really just me saying "citation needed" using 50x as many words)
    But this is academical because @Hecaton has excavated the rule that guides the answer to this situation.
    RobertShepherd likes this.
  5. ijw
    No. Boost requires the Perimeter Automatic Special Skill in order for the CrazyKoala to be able to declare AROs, and
    • Automatic Special Skills and Automatic Equipment have no effect while in the Disconnected state.
  6. DukeofEarl
    DukeofEarl Well-Known Member
    That's not the reason the EVO Bonus doesn't work from my understanding. Importantly it is not the reason that the FAQ gave either (it doesn't give one)
    N3 Frequently Asked Question FAQ Version: 1.1
    Q: Can the bearer of an AI Beacon use the +3 PH Bonus to Airbone Deployment provided by an EVO Hacking Device?
    A: No.
    Related Pages: AI Beacon, EVO Hacking Device
    The EVO bonus doesn't work on AI Beacons because of Deployment timing. The EVO isn't on the table in a way that can provide the bonuses until after Deployment is over.
    Robock, ChoTimberwolf and Hecaton like this.
  7. Hecaton
    Boost is an ARO, and a "Perimeter Item" remains so even if it is Disconnected.
    Moreover, secondary to what you're saying, TO's at multiple events I've encountered (Satellite tournaments and tournaments at GenCon) have ruled that equipment can't be put into states that talk about Troopers, period.
  8. ijw
    How does a non-trooper declare an ARO?
  9. ijw
    Sorry, didn't see the edit.
    That's the first I've heard about this. You're fully aware that I have no control over referees' decisions at events, and it has no bearing on the actual rules anyway.
  10. Hecaton
    If it's a Perimeter Item. So as not to seem snippy or tautological, I don't see how something stops being a Perimeter Item if it's Disconnected.
    Sure, but the "deployable equipment is not troopers" idea is causing problems is my point; CB could really do us all a favor by clarifying that.
  11. ijw
    Being a Perimeter Item doesn't allow something to declare AROs. The Perimeter Special Skill allows it to declare AROs. And that Automatic Skill is not in effect.
    I agree. So why are you dragging me into it, by claiming that I've said things that I didn't say?
    chromedog and A Mão Esquerda like this.
  12. Hecaton
    All it takes to declare Boost is being a Perimeter Item.
    Most of them cite you as the reason for the ruling. I don't know what goes on on the WarCor forums.
    #32 Hecaton, Apr 26, 2019
  13. ijw
    Attempting to unravel that...
    "All it takes to declare Boost is being a Perimeter Item."
    Troopers declare AROs. Deployable weapons and equipment are not troopers. Without applying the Perimeter Special Skill, there is no permission for a CrazyKoala to declare an ARO.
    "Most of them cite you as the reason for the ruling. I don't know what goes on on the WarCor forums."
    Then get them to come on the forum and say that. Nothing that's been discussed on the Warcor forum has covered this in any way, and I have not told anyone to rule that way.
    You have made false claims about me. That might have been by mistake, but you still need to retract or apologise.
  14. Hecaton
    There's nothing in the Perimeter rule itself that grants a Perimeter Item the ability to declare an ARO; in fact, the Perimeter rule specifically *restricts* AROs they can perform to Boost. It's the Boost ARO itself that says Perimeter items can perform it.
    Nah, man. You're still promoting selectively applying the trooper/deployable equipment distinction in a way that makes it impossible for casuals to pick up the game by reading the rulebook, which is the biggest problem Infinity has.
  15. ijw
    So you've made false claims, you know they're false, but you won't apologise or retract the claims. So be it.
    Zewrath, tox, chromedog and 1 other person like this.
  16. Hecaton
    I don't think they're false because you're still hypocritical on the point with Disconnected I brought up; also, if I remember correctly, you said that Guided ammo couldn't be fired at non-trooper things that were targeted, which would fit in the same category as things like AI Beacons being isolated and not able to play host to Posthumans.
  17. Mahtamori
    All due respect, that's your own interpretation, as other deployment rules are sequential and as far as I know nothing is turned off while deploying. Again, adding on text that simply isn't there to a rule can have further consequences and you haven't been able to actually point at a page where it says "as if a trooper", so let's just agree to disagree until such a time as you can produce such a line.
  18. DukeofEarl
    Fair enough. Your claim that they do not benefit due to "not being a trooper" is adding text as well and my purpose was more in pointing that out.
    I never claimed anything about "As if a trooper" though. I think you are mistaking me for other posters.
    I recall conversations on the old forums stating the reasoning was due to the deployment timing and reiterated that.
    Robock likes this.
  19. Mahtamori
    Interesting side note; while the Perimeter skill tells you to enter a Perimeter Weapon into the Disconnected state, it can't be cancelled because all cancellation clauses require "this trooper"
  20. Mahtamori
    Yes, I'm mistaking you for Robock. Sorry about that :/
    And in fairness, reviewing the AI Beacon skill and the EVO Hacking Device, the real reason why they don't benefit from the +3 during Deployment is much simpler: because CB says so in the FAQ.
    Neither the deployment jazz nor the trooper reason holds up to inspection of the actual rules, which feature none of them.
