    Dismiss Notice
Zlavin mod
Discussion in 'Rules' started by konuhageruke, Nov 17, 2019.
  1. konuhageruke
    Ave
    With zlavin and especialy with connungtion with koorie mod there is a posibility that one of players will not be able to pick a character
    If both have the same set of Characters, abcdefgh, and one is banned the rooster may become abcdefg on both sides. Then player one chooses a, 2 picks bc, 1 de, 2 fg, 1... The last one has no character to choose from.
    No I may face a situation exactly like that, but even more dire. One of players has Compass sponsor, so he can ban additional character from the "Initial Alignment". First of all, how would that work in non League event. Secondly - with overall combination, one player must choose from 6 characters while other will from 7 but they block already chosen characters.
    Again how to resolve situation when I have no character to choose from?
  2. CAnon
    CAnon Well-Known Member
    That's really only likely to be a problem if you both only have the Core box (in which case you'd likely both ban Musashi, and end up in the situation you described).
    If you have even 12 characters each, the odds of you exactly replicating each others 8-character lineup is low (to say nothing of if you have all 30 currently released). So it's unlikely to be a real issue.
    That said, if it DOES somehow occur, i'd say that you should just ignore the effects of Koorie.
  3. konuhageruke
    But as you wrote: it is possibile, and should be addesed by officials. So @-V- , what would you suggest here?
    And what about compass? How does it work outsider league games?
  4. HarlequinOfDeath
    I tried to fix this problem in my league v2 idea as well.
    Both players have the same 8 characters.
    You can still ban a character from the 8 man lineup. But as soon as the characters are picked as usual following the Zlavin mod afterwards. If the situation occurs that one player cannot pick a third or fourth character the ban/bans is/are negated and he is allowed to pick that/these character/s.
    Ealthril and AdmiralJCJF like this.
  5. AdmiralJCJF
    Personally I favour the simple solution of "playing without Zlavin".
    YMMV
  6. HarlequinOfDeath
    I don't like mirror matches. :)
    Ealthril likes this.
  7. AdmiralJCJF
    Haven't ever seen one of those.
    Despite having played 0 matches with the Zlavin mod.
  8. konuhageruke
    That is uncommon and hae rather small probability, but the chance exist, and I think that should be addressed.
  9. HarlequinOfDeath
    If you take a look at the most preferred characters in TTS leagues or non-TTS events some core characters are highly contested. So I could imagine very many mirror picks without Zlavin. I don't like this to happen.
    But if you want to avoid the problem with Zlavin + Koorie you could force a handicap to the player by using Zlavin + Croepoek.
  10. AdmiralJCJF
    It's fair enough that it should be addressed.
    I think that cancelling the ban if it prevents a legal team (at the discretion of the "victim" on which they ignore first) would resolve the issue.
    Zenon likes this.
  11. -V-
    -V- A! Team member
    People usually play only one mod. Zlavin and Koorie have been living with each other since AGL was born and we've never been reported about any issue. I think because they never were played together.
    You're right: There's a chance to get stuck, especially if Compass is in play. I'm noting down to give an official answer about it. Meanwhile, my recommendation is to apply common sense by the organizer and the golden rule: a player must play exactly with 4 Characters in their team. This rule takes precedence over AGL Rules.
    Thanks for your question.
    AdmiralJCJF likes this.
  12. Ealthril
    Ealthril Well-Known Member
    As a tournament organiser, when I chose to combine Zlavin + Koorie queen mods, I told to participants that if any of them have the exact same 8 characters, it disables Koorie queen mod, and they just apply Zlavin.
    Zenon and -V- like this.
  13. konuhageruke
    now
    If there is Zlavin
    Coorie
    Compass in play.
    Whitch AGL rule should be cancelled first?
    Both Coorie and Compass are used to ban most crucial enemy character.
    But Zlavin is also used to block those those we don't want enemy to have. If Zlavin, then in what order do we cancel blocked character?
  14. konuhageruke
    Hey @-V- sorry to bother you, but I'm going to attend to a tournament where this exact situation may appear, and i would like some clarification on sequence of cancellations ;)
  15. -V-
    -V- A! Team member
    Don't bother at all! I would suggest giving the highest priority to Compass (as it depends on the player's results). Then, Koorie, but I'd make an exception: if the same player activated Compass' Effects they couldn't use Koorie (only if you want to give room to Zlavin mod). And at last, Zlavin.
    Should a player is going to select a char, and it's impossible to their opponent exclude the char from their team (because they don't have more chars and need this char to make the 4 chars team), then Zlavin doesn't apply (and the char will be copied).
    That's a way to solve it. And it's a suggestion, not an official answer. As the organizer, you must decide how to proceed.
    :wink:
    volgo and AdmiralJCJF like this.
  16. konuhageruke
    Thanks a lot!
