White noise on a repeater for movable zone?
Discussion in '[Archived]: N4 Rules' started by KGG, Mar 10, 2022.
  1. KGG
    KGG Well-Known Member
    Can you drop white noise on a repeater such as a repeater REM and move the REM around, thereby adjusting the area of affect of the white noise zone?
    If so, how does it work during the order sequence?
    If a white noise enabled repeater REM moves past an MSV2 enemy, no line of fire can be drawn?
    Does the movement of a white noise enabled repeater unit 'smear' the white noise zone during that movement/order? - so you can decide to shoot while its in the way, or after its moved past?
  2. Willen
    Willen Well-Known Member
    Once you put down a template, it does not move. I cannot recall any that would do that, the White Noise being no exception. So the answer is no.
    NorthernNomad and KGG like this.
  3. KGG
    Thanks,
    Yeah I think you're right. In my head it goes 'on the repeater' but the wording just mentions placing a template, so it's static on the board and not 'attached to the repeater' or anything like that. Cheers, I should have read the wiki better!
    Willen likes this.
  4. Willen
    You are exactly right, all the wording is "placing a template". A moving white noise mini zone is basically... Albedo.
    KGG likes this.
