Which model are you using for for LGL Ghulam?
Discussion in 'Haqqislam' started by onko, Aug 3, 2019.
Tags:
  1. onko
    onko New Member
    Which of the Ghulam models? Are you using other proxy or have you modified a ghulam sculpt (deep down hoping for a picture :) )
  2. Errhile
    Ask, and you shall receive:
    This is the 1ed. Ghulam sculpt (as the other two, the one ob the right is the 1ed Hacker).
    I removed the underbarrel shotgun, and replaced it with a 1:35 scaled M203 underbrrel GL from an accessory sprue of a Trumpeter-made gun set in 1:35 (either this one or a similar one).
    Of the current edition, I'd say the knife-wielding Ghulam should be a good candidate (since he's not holding the rifle's foregrip).
  3. BrianJ
    BrianJ Well-Known Member
    After considering a variety of conversion options I just ended up settling on using the good ol huzacutie LGL model for the time being since she can't even be in RTF.
    Palomides likes this.
  4. Kraken1130
    Kraken1130 Well-Known Member
    I did an arm swap with the Hunzakut and Ghulam Sniper to get a Hunzakut sniper and Ghulam LGL.
    theGricks likes this.
  5. theGricks
    theGricks Well-Known Member
    I took an extra muyib LGL arm and swapped it with the knifing ghulams rifle arm.
  6. Myomer
    Myomer Tyrannosaur in an F-14
    I clipped the flamethrower element off the old LFT naffatun from the starter box. Looks LGL enough for me...never mind the helmet.
    oldGregg likes this.
  7. Lexington
    Lexington Cartoonist at Large
    Creating one out of, like, seven different parts from four different miniatures, because I am a glutton for self-inflicted punishment.
    Barrogh and emperorsaistone like this.
  8. Maverick
    Maverick Member
    I just use one of the two Muyib with GL models I have. They can't be taken in RTF so there isn't any confusion.
