What are troops for Tactical Window?
Tema en 'ITS' iniciado por wildchevy, 2 Sep 2019.
  1. wildchevy
    wildchevy Well-Known Member
    25 Abr 2017
    TACTICAL WINDOW
    This Extra means the scenarios have a narrow window of insertion, with a tactical advantage, allowing for only small teams and a support group to be inserted into the zone of operations. So, players are not allowed to use Army Lists with more than 15 troops.
    Looks like Netrods and helper bots are classified as support troops in Army but are equipment. Puppets have no classification in Army. Proxies are classified as troops with G:Jumper.
  2. kinginyellow
    19 Dic 2017
    Helper bots aren't classified as equipment.
    A Hecaton le gusta esto.
  3. Robock
    Robock Well-Known Member
    It is the same as LI but 15 instead of 10. I think the general idea is easy to get.
    (i know, more specifically LI doesn't say 10 troops. It says 1 combat group. It is the combat group rule that says only 10 troops per combat group. So whatever count as 10 troops per combat group count as 15 troops per army list)
    A Ayadan y Barrogh les gusta esto.
  4. Hecaton
    It doesn't use the same wording.
    What about G:Synch, G;Servant, Antipode, AI Beacons, and Posthumans? As it stands these kind-of-sort of count as troopers sometimes.
    A xagroth le gusta esto.
  5. Cannon Fodder
    29 Dic 2017
    I had the same question, Until I hear otherwise I'm going on the basis that any model that generates any number of orders as troopers.
    G:Servants = 0 troops
    Scarface & Cordelia (2 models hired at the same time) = 2 troopers
    Peacemaker & Auxbot (G:Sync) = 1 trooper
    Netrods (AI Beacons) = 1 trooper
    Yuan Yuan (Irregular & Impetuous) = 1 trooper
    Zewrath, ChoTimberwolf, Robock y 4 otros les gusta esto.
  6. Sabin76
    It's not the same wording as LI, but it is the same wording that restricts a combat group to 10.
    A Robock y Ayadan les gusta esto.
  7. toadchild
    22 Feb 2017
    If models don't count towards the combat group limit then they don't count against this limit, either.
    chromedog, DukeofEarl, Robock y otra persona les gusta esto.
  8. Savnock
    Savnock Nerfherder
    25 Nov 2017
    EDIT: Nevermind, I found the post where someone quoted all the unit descriptions which say most G:Synch units count as one trooper.
    #8 Savnock, 14 Ene 2020
    Última edición: 14 Ene 2020
  9. HellLois
    25 Abr 2017
    Thats the way Tactical Windows works. In the next update, I will fix the woording.
    Stuffist, KestrelM1, inane.imp y 2 otros les gusta esto.
