Hi everobody, Can we use the Warning rule for reveal a TO in hidden deploiement if a friendly model die in this ZOC ? Warning allows an automatic movement which doesn't require any Roll. The warning rule can be find here : http://infinitythewiki.com/en/Warning If a TO can quit the hidden deploiement, the model is again in TO marker or he is reveal himself ? Thx :)
The cancellation clauses of Hidden Deployment each require that a -skill- be declared: The Hidden Deployment state is automatically canceled whenever the trooper declares any Short Skill, Entire Order or ARO. If the Hidden Deployment trooper declares Cautious Movement or any other Short Movement Skill that does not require a Roll (except Alert), then his state of Hidden Deployment is canceled. Place a TO Camouflage Marker (TO CAMO) in the position you wrote down during the Deployment Phase. If the trooper declares a Skill or Entire Order other than those previously mentioned, the Hidden Deployment state is also canceled. In that case, place the model that represents the trooper in the position you wrote down, facing in the direction of your choice. Warning doesn’t satisfy any of those requirements.
What the heck does it mean by "except Alert" in there? Does this mean that models in Hidden Deployment can call Alert all they want without revealing themselves?
Nah, Alert doesn't require a roll, but reveals the trooper. Warning! seems to be intended to give nearby troops a chance to turn around and face the attacker...as markers (also in hidden deployment) already have 360° LoS, this is redundant. If you want to get that guy on the table, you need to declare an ARO.
