When you include one of these troops in your army lists, which one of the two options do you usually use more and why?
Definitely 360 visor. It's IMO better to guard deployment zone. And it looks better on the battlefield ;) PozdRawiam / Greetings
Only 360 visor. you don't care about correctly placing the miniature, and also as said earlier, good for defending the deployment zone or flanks. Don't forget that if you barely can hit the enemy (bad range, mimetism-6), or it has total immunity, or camo marker is trying to flank, you can always declare Look Out! as an ARO in order to try turn some of your units that might be facing different direction
Thanks for the answers. And I launch a new one. Do you also use the option with the 360 Visor in other armies or does it depend on each army (just out of curiosity)?
The 360 warcor is universally better. There's no joining fireteams or anything else that might make the sixth sense better for a certain army.
I’m of a similar school of thought to many of the posters above, 360 visor all the way. It’s been far, far more useful than the other profile to me.
This is really weird as I’ve been taking the 6th Sense version for a while now. You’re far enough back that it’s rare you need to see behind you. You get to shoot back without -6 if someone tries to Smoke / MSV you. If someone shoots you in the back you still get to shoot back.
If somebody wants to use orders to set up smoke+MSV on my warcor, I am ok with that. The issue for the 360 visor for me is more about being able to react out of ZoC with a Flashpulse to AD, no matter the angle. That is a normal roll much easier and likely to success than a FtF Flash Pulse vs being shot.
