Vaulting 'Over'
Discussion in '[Archived]: N4 Rules' started by spears, Mar 15, 2021.
  1. spears
    spears Well-Known Member
    Just a quick sanity check to make sure I've not been playing this wrong forever. When vaulting over at ground level is this legal?
    Or is over intended to mean you have to finish the other side.
    Watching this, because I don't think this was ever clarified, even in N3.
    I do think the rules aren't preventing it, but it'd be interesting if moving over an obstacle required a straight path.
    Methuselah and inane.imp like this.
  3. spears
    And as a follow which if any of the below are legal?
    A.
    B.
    C.
    Edit: edited c
    #3 spears, Mar 15, 2021
  4. solkan
    solkan Well-Known Member
    There can’t be a requirement for a “straight” path. Because that would prevent vaulting over curved obstacles in various situations.
    Robock likes this.
  5. Robock
    Robock Well-Known Member
    that is what i was thinking too. There is two side for a vault : the side you start on and you side you finish. Both the starting and finishing side must be not too high.
    You could think the finish side to count is the one opposite to the starting side (based on example pictured) but that would prevent vaulting on curved obstacle, or vaulting on a 4-sided column/post and landing on a side other than the one opposite where you hopped on.
    Those situation being allowed to exist, means you must consider the "other" side of the vault as being the side where you land, not necessarily the side opposite where you started; which for the 2d rulebook example is the same thing anyway.
  6. ijw
    B is definitely illegal, as you'd be trying to vault towards a drop that's higher than your Silhouette Template.
    Abydog and spears like this.
  7. spears
    Thanks, is it safe to assume the others are legal or are they 'no comment'?
  8. Vohlere
    Vohlere Active Member
    And where would be the 'tipping point' between B and the others?
  9. ijw
    I think they'd be legal.
    As soon as any part of the Silhouette goes over a drop taller than the Silhouette.
    Dragonstriker, spears and Vohlere like this.
  10. Vohlere
    Makes sense! Thanks =]
  11. spears
    Much appreciated.
  12. Mahtamori
    Like I wrote I don't think that's how it is, but rather that it'd be interesting if it were. However, I don't see how the shape of the obstacle would have any impact on whether your path over it was straight or not, particularly if you keep in mind that some situations would allow you to use the "squeeze" mechanic.
  13. spears
    Sorry but just for completeness (this is a difficult one for 2d) Is this legal, or only legal if your path forces you to do it.
  14. ijw
    Only if your path forces you to do it.
    spears likes this.
  15. kinginyellow
    What would force your path to do it?
  16. Nuada Airgetlam
    A wall and this area being a thin ledge, for example.
  17. ijw
    A ledge that isn't wide enough to support your base. Imagine a solid wall behind the translucent Silhouette.
  18. spears
    [​IMG] Like this
    ijw, colbrook and Nuada Airgetlam like this.
  19. ijw
    Exactly.
  20. kinginyellow
    Awesome, that makes sense.
