Vaulting over a parapet
Tema en '[Archived]: N4 Rules' iniciado por karolis, 18 Abr 2021.
Estado del tema:
  1. karolis
    karolis Member
    10 Dic 2017
    Can the trooper move forward and just with some part of the baze vault over the parapet , and then go back and finish his move on a normal surface (as in attached image )?
    Adjuntos:
    A karolis y inane.imp les gusta esto.
  3. Sirk
    Sirk Well-Known Member
    17 Mar 2021
    I think the ambiguity here could lie in the original rule, as we are used to say "vault" but the actual text is "move over any scenery..".
    The point is that -over- in English can mean both -upon- and -across-.
    The first meaning would suggest a clear "yes, you can", the second meaning would open to the discussion if going back can technically be a valid use of moving across.
    As far as I can see by English not being my first language.
    A karolis le gusta esto.
  4. inane.imp
    28 Ene 2018
    Based on extensive discussion in several threads read "over" as "upon" not "across".
    (search the forum for inane, IJW and vault).
    A Sirk y karolis les gusta esto.
  5. Sirk
    17 Mar 2021
    Good to know, thx.
Estado del tema:
