V: Dogged and G: Remote Presence
Discussion in '[Archived]: N3 Rules' started by Cannon Fodder, Apr 20, 2019.
  1. Cannon Fodder
    I'm going over the V: Dogged and G: Remote Presence rules and recall a rule that said you can have 1 or the other, but not both activated at the same time. Meaning that you could not have a model take a wound, go dogged (L1 Unconscious), then keep going, take second wound (L2 Unconscious), keep going until it take 1 more. But on second reading I think it means you can't go undogged when you enter L2 unconscious. The second example below seams to say you can get 2 level of unconscious with dogged, or is that mean he "wakes up" after being unconscious. Can someone confirm.
    N3 Frequently Asked Question FAQ Version: 1.2
    Q: How do V: Dogged and G: Remote Presence interact with each other?
    A: When a trooper that has both skills enters the Unconscious state for first time, the player controlling it has to choose which to use.
    If the player chooses to activate V: Dogged, the trooper will ignore the effects of the Unconscious state and enter the Dogged state. That means that the trooper will enter the Dead state at the end of the Turn, or if the trooper suffers a new wound before the Turn ends.
    If the player chooses to use G: Remote Presence, the trooper will suffer the effects of the Unconscious state, but will gain a second Unconscious level before entering the Dead state and it could be repaired meanwhile.
    Related Pages: Dogged, G: Remote Presence, No Wound Incapacitation, Unconscious, V: Dogged, V: No Wound Incapacitation
    N3 Frequently Asked Question FAQ Version: 1.1
    Q: If a trooper with G: Remote Presence and V: Dogged enters the second level of Unconsciousness, can he use Dogged?
    A: Yes, because V: Dogged can activate when the trooper entered the Unconscious state.
  2. colbrook
    You can go Dogged when you enter the Unconscious state.
    For example, if an undamaged Unidron Batroid takes 2 wounds in an order it will enter the second level of the Unconscious state, and can activate Dogged.
    However, if the Unidron had taken 1 wound previously and chosen not to use Dogged, taking a second wound in a later order and going from the first to second level of Unconscious does not trigger Dogged as it is already in the Unconscious state.
    Once you enter the Dogged state any further wound kills the trooper, regardless of which level of Unconscious was entered.
    #2 colbrook, Apr 20, 2019
    chromedog and toadchild like this.
  3. Mahtamori
    Yeah, the reason why the FAQ doesn't discuss what could potentially happen if a trooper is already in Dogged state and takes damage is because the Dogged state specify that the trooper outright enters Dead state if it takes another damage.
