Using a "Snapships" model as scenery
Discussion in 'Scenery' started by Lawson, Dec 22, 2021.
  1. Lawson
    Lawson Well-Known Member
    I've been interested in the possibility of using Snapships toys as scenery for my table. Their scale is technically wrong... more like 15mm or 1/144 scale, but there was one ship in particular that I felt like I could make work for Infinity due to the size of its cockpit.
    This cost me about $27 on Amazon, so the price was right for a piece of terrain.
    Over the past month I worked on painting it up, utilizing some scale modeling techniques/tools that are new to me, such as chipping medium and oil washes. Here's the result:
    It was a fun experiment and turned out better than expected. I'd definitely recommend this to anyone who wants a ship for their table but doesn't want to pay a premium for a hobby miniature model.
  2. It looks spectacular, congratulations!
    Abydog likes this.
  3. Koin-Koin
    Nice model and great results.
    For me it's a totally valid piece of scenery (and a gorgeous one)
    Abydog and chromedog like this.
  4. jherazob
    Excellent results!
    One thing about the scale for ships with a cockpit that is too small for our minis: This is Infinity, they can be autonomous vehicles and therefore be smaller than a normal craft, the cockpit only has avionics or something like that and has no need for a human operator. That works for anything from ships to vehicles to many other such things. Not everything can be used this way but it still should greatly expand our choices :smiley:
    Abydog and Lawson like this.
  5. Lawson
    The snapships models are sort-of like Lego so in theory one could make any number of cockpit-less ships or vehicles. Worth considering.
    Abydog likes this.
  6. Dragonstriker
    That is a phenomenal paint job. It really turned something toylike into a fitting scenery piece.
    Abydog, chromedog and Lawson like this.
  7. timberfox
    timberfox Active Member
    that looks wonderfull what a good repaint can do.
  8. Red Harvest
    The paint job really sells it. Very tacticool. The Ariadna version, the high tech version by Ariadna standards, runs on a coal powered steam engine, no? ::grinning:
    With things like this plasticard is usually your friend. How difficult would it be to convert/modify this using plasticard?
    Asking for a friend myself.
  9. Space Ranger
    If you didn't say it was a "wrong" scale, I never would have known. Unless there's some sort of real life reference, how would we know? That looks fantastic to me!
  10. Lawson
    It's only the "wrong scale" in the sense that the Snapships pilots that go in the cockpit are something like 15mm miniature scale. Many of the snapships cockpits seat one pilot and so they look relatively small... but this particular cockpit is a tandem seater and so it manages to look approximately the correct scale for a single pilot ship in Infinity, essentially. Certainly with kit bashing one could put together other things that were a good scale for 28mm miniatures using some of their other kits.
  11. Lawson
    I would imagine you could make modifications with Plasticard. Snapships themselves are a toy product that works almost like LEGO as well so you could probably buy a few kits and bash them to get closer to what you'd want. A good use for plasticard actually might just be covering over any open 'stud' connectors between the ship parts which give away the brick-construction.
    Here's a reference (not my photo) of what the pieces look like mid-construction.
    As you can see, most of the 'show' pieces begin to cover up the basic bricks but there will usually be some open holes in the finished model unless you got multiple kits and cannibalized them for some additional covering pieces. That could make the model overly busy though, so I think plasticard would work well for flat surfaces.
  12. Mob of Blondes
    Web site has a bunch of manuals, so you can check what parts you get.
    What is the size of each base cube?
  13. Space Ranger
    Those cubes alone look pretty cool and would be great painted up as scatter terrain.
  14. Lawson
    The cubes are about 20mm square, not counting the single plastic stud that protrudes from one side. The interior blue section is rubber-ish and is slightly flexible which is what allows the plastic stud to 'snap' in. @Space Ranger you're right they are probably about the right size to function a scatter crates if you cut the stud off and placed that side face-down. Could also work as "supply boxes" for the requisite mission if you put them on a 25mm base.
  15. Space Ranger
    Actually I was thinking the that part is good! It could be painted to look like a light, vent, or some scifi gadget.
  16. Lawson
    It certainly could! Sky's the limit.
