Tokens and how to
Tema en 'ITS' iniciado por Arkaon1125, 26 Mar 2019.
  1. Arkaon1125
    Arkaon1125 Well-Known Member
    13 Abr 2018
    Since i'm a new player how and where can i obtain the tokens needed to play? I have found the downloadable file to print myself and the initial idea was to print on rigid paper and the plastificate it, to let them be more durable and solid.
    But any other ideas on how to create my own tokens and/or where i can buy it.
    I have a 3d printer myself (an mk 3 Prusa) but i'm not findin aniwhere the models of the tokens.
  2. CoolDiscoDan
    CoolDiscoDan New Member
    4 Mar 2019
    You can buy these 1 inch clear acrylic pendent caps. They are used for jewelry making, then cut out paper tokens fit inside them almost perfect. They have an adhesive inside the paper sticks in there nice. They are pretty durable for the price.
    Adjuntos:
    A Arkaon1125, Brother Smoke y colbrook les gusta esto.
  3. Brother Smoke
    19 Dic 2017
    Look up round clear epoxy stickers on Amazon, they are cheap and putting one on each side of a paper token makes it pretty much as good as professional plastic ones
    Edit - Ninja'd! but yeah those are the ones
    A Arkaon1125 y colbrook les gusta esto.
  4. colbrook
    If you get a 1 inch round punch it's even easier, print the tokens, punch them out, then stick on an epoxy dome.
    You can also make double sided tokens with Wound/Unconscious for example
    A rushputin, Arkaon1125 y Brother Smoke les gusta esto.
  5. Arkaon1125
    13 Abr 2018
    Are the Epoxy stickers a bit round?
  6. colbrook
    They're slightly domed
  7. Arkaon1125
    13 Abr 2018
    Thanks, i'll give them a try. The downloadable paper are of the right size? I mean they are already 1 inch round if printed in a 100% scale?
  8. Brother Smoke
    19 Dic 2017
    They should be, give or take a fraction of a millimeter. If you get a 1-inch hole punch it should be fine
    A chromedog le gusta esto.
  9. Lameth
    Lameth New Member
    6 Nov 2018
    Hello all. I take the opportunity of this thread to ask a question.
    I am also quite new to infinity and a panoceanian player.
    I was wondering what are the minimum heavily usefull tokens to have in addition to the folowing ones: command, orders, camo, TO Camo, prone, suppresive fire, wound, mine, fireteam leader (core and haris).
  10. colbrook
    The markers will be 25mm so a 1 inch punch is technically 0.4mm larger, though I imagine you can get 25mm punches too.
  11. CoolDiscoDan
    4 Mar 2019
    I made two sets of the printed sheets and I have more than enough. The only thing my sheet didn’t have was two different colors for regular orders. Having two different colors is helpful to keep your orders of different combat groups separate.
  12. Daniel Darko
    17 Feb 2018
    A toadchild y xagroth les gusta esto.
