Tohaa and Transmission Matrix
Discussion in 'Tohaa' started by ChoTimberwolf, Jun 21, 2018.
  1. ChoTimberwolf
    So in some weeks I got a tournament coming up, unmasking, supplies and transmission matrix. Got one list for unmasking and supplies which I need to test but it looks good on the other hand transmission matrix is giving me quite a headache so far. Got 3 lists:
    First list:
    [​IMG] Transmission
    GROUP 1[​IMG] [​IMG] [​IMG]8
    [​IMG] CLIPSOS Minelayer Combi Rifle, Antipersonnel Mines / Pistol, Knife. (0.5 | 25)
    [​IMG] RASAIL Lieutenant Viral Combi Rifle + 1 Chaksa Peripheral / Pistol, Knife. (0 | 39)
    [​IMG] [​IMG] CHAKSA PERIPHERAL Heavy Flamethrower / Pistol, Knife. (- | 4)
    [​IMG] SUKEUL Missile Launcher, Light Shotgun / Pistol, Breaker Pistol, Knife. (1.5 | 36)
    [​IMG] GAO-RAEL Sniper Rifle / Pistol, CCW. (1 | 31)
    [​IMG] KAELTAR (Chain of Command) Light Shotgun, Flash Pulse + 2 SymbioMates / Pistol, Electric Pulse. (0.5 | 21)
    [​IMG] CHAKSA AUXILIAR (Baggage, Sensor) Heavy Flamethrower / Pistol, CCW. (0 | 10)
    GROUP 2[​IMG] [​IMG] [​IMG]6 [​IMG]1
    [​IMG] SUKEUL HMG, D-Charges / Pistol, Breaker Pistol, Knife. (1.5 | 35)
    [​IMG] MAKAUL Heavy Flamethrower, Eclipse Grenades / Pistol, Viral CCW. (0 | 13)
    [​IMG] KAAURI Sentinel Submachine Gun, 2 Nanopulsers, Nullifier / Pistol, Electric Pulse. (0 | 12)
    6 SWC | 300 Points
    Second List:
    [​IMG] TM 3
    GROUP 1[​IMG] [​IMG] [​IMG]7
    [​IMG] TAQEUL (Chain of Command) Viral Combi Rifle, SymbioBugs / Pistol, Knife. (0 | 40)
    [​IMG] KAMAEL Combi Rifle / Pistol, Knife. (0 | 12)
    GROUP 2[​IMG] [​IMG] [​IMG]7 [​IMG]1
    [​IMG] SUKEUL Lieutenant (Forward Observer) K1 Combi Rifle, D-Charges / Pistol, Breaker Pistol, Knife. (0 | 32)
    4.5 SWC | 300 Points
    So how would you make a list for that? Or what do you think of my lists
    Thaddius likes this.
  2. Thaddius
    Thaddius Well-Known Member
    I might consider changing around the groups. The Taqeul/Rasail needs orders but the Gao Rael/Sukeul ML triads probably wont.
    I would make an order group of 10 and put the Sukeul/Gao Rael Kaeltar in the other group with a Clipsos ML. This way you can feed more active turn pieces. With transmission matrix hopefully you won't need to move the ARO triad and they're scoring. You'll need to move up eventually with others and hopefully Chaksa into scoring positions or trading up on pieces that may try to deny you.
    n21lv likes this.
  3. ChoTimberwolf
    Thank you my thoughts were that in List 1 Group 1 the Rasail usesy the orders and in group 2 the sukeul hmg and in the other lists its the taqueul in group 1 and the sukeul k1 using orders.
    I played lots of limited insertion games these past months so have kind of a hard time to get a decent list done with 2 combat groups :(
  4. Thaddius
    Fair enough. My concern with separating my strike pieces into different groups is that it's harder to manage the inevitable loss of orders in a particular group. If orders are taken away from a group in which your attack piece is it becomes harder to fuel it later in the game.
    I rarely find that my defensive triad uses many orders and 4-5 is generally enough to feed that in a game anyway. Having multiple attack pieces in a main combat group also gives you options should one strike piece not be in an optimal place you always have another that can be used.
    n21lv likes this.
  5. ChoTimberwolf
    I am not quite sure what you mean I got in both groups attack pieces (clipsos, taquel, k1 triad, hmg triad, rasail) and order pieces like the chaksas, kaauris, defensive triad. But yeah I will rework these lists
  6. n21lv
    n21lv SymbioHate
    I would definitely rework your group organisation and put all attack pieces in one group while leaving support and ARO pieces in the other. That way it won't hurt that much when you get robbed of 2 orders if you go first.
  7. ChoTimberwolf
    But what will I do with the orders of the group that has no attack pieces? Loose the orders cause they can't do anything useful?
    Zsolt likes this.
  8. Zsolt
    Zsolt Well-Known Member
    My thoughts exactly. It’s a good idea to have a support group and put your hacker there so setting up supportware won’t take orders away from your main group, or have a tag in the first and an engineer in the second, so when your tag goes down you still have some orders for your engineer to run there and repair it.
    But apart from that it seems like a good idea to have some attack pieces in both groups, so you can not only use 10 orders but 14 or 16 efficiently.
    If all your good attack pieces are in the same group, they take away orders from each other.
  9. ChoTimberwolf
    Exactly sure we Tohaa can use some command tokens to shuffle units around but having one group completly dedicated for attacking and the other for defending...I fail to see the point..
    This is my newest list:
    [​IMG] TM 4
    GROUP 1[​IMG] [​IMG] [​IMG]9
    [​IMG] KOSUIL Minelayer K1 Combi Rifle, D-Charges, Antipersonnel Mines / Pistol, Knife. (0 | 25)
    [​IMG] KAMAEL Lieutenant Combi Rifle / Pistol, Knife. (0 | 12)
    6 SWC | 300 Points
    One Kauri and one chaksa for each point on my side to defend them, defensive triad to annoy the hell out of them, two clipsos to start at the middle point, k1 kosuil to hunt HIs and TAGs and of course sukeul hmg to hunt aro pieces, not super happy with it but at least it got lots of orders
    Wombat85 likes this.
  10. n21lv
    n21lv SymbioHate
    Repositioning and providing support. You don't win battles by just standing there not reacting to enemy movements.
    There are always pieces in your list that will need a lot of orders (Rasail, your killy Triad, your specialists) and units that will need just some (ARO pieces, support troops), and that's why you need to separate them into different combat groups. You also need to understand that you don't and shan't use every unit in your list at least once a turn. There might be some dudes that will just stand there seemingly doing nothing, but they:
    1) provide orders
    2) deny an area
    3) distract your opponent
    If you intend to activate every attack piece you got in your list, you're doing it wrong.
    P-Chan and Zsolt like this.
  11. Wombat85
    Wombat85 Well-Known Member
    This. Ideally only one or two of your big hitters are being fueled per turn, with the rest being in a position to react and jump on opportunities next turn.
  12. ChoTimberwolf
    Thanks for explaining still isn't it better to have in both groups units that can use these orders? And units that probably won't use them so the others can use it?
    Zsolt likes this.
  13. Abrilete
    Abrilete Well-Known Member
    Yes, that's a nice setup.
  14. n21lv
    n21lv SymbioHate
    You will have units that can use those orders in both groups anyway, yet you want to avoid that awkward scenario when one of those units runs out of orders because they are in a group that only provides 4 when you need 6. Also, coordinated orders require units to be in the same group, so if you intend to use them, think about your group composition in advance. Finally, you need troops for rebuilding your Triads to be in one group.
    That said, I would consider swapping the Triads between your groups. ML Sukeul is a great ARO piece and Gao-Rael Sniper also doesn't need that much orders, but your HMG Sukeul definitely will.
    #14 n21lv, Jul 2, 2018
    P-Chan and ChoTimberwolf like this.
  15. Abrilete
    Yes, forgot the HMG Sukeul was in Group 2.
    Anyway, thanks to the Light Shotgun the ML Sukeul is also deadly in Close Quarters, I once whiped out the enemy list just with her moving and shooting every turn while getting closer and closer to the enemy.
    ChoTimberwolf and Zsolt like this.
  16. ChoTimberwolf
    actually most of the time the 6 orders are enough for me to kill the enemy aro pieces with the sukeul and when I want to bring my kosuil triad closer, i now swapped one kamael with the makaul from the sukeul triad to make it easier to get closer, I dislike using the sukeul ML in active turn cause the burst doesn't improve ;)
  17. Magonus
    Magonus Well-Known Member
    With how little is hackable in Tohaa, this is one of our best missions. We are very good at moving 30+ points to a new location in a couple orders, so even if you are going first, your Rasail, Chaksas, and Sukeul teams should be able to aggresively camp the antennas.
    Remember that if the Rasail is your DataTracker, only the Rasail himself counts for the HVT kill, not the Chaksa.
    #17 Magonus, Jul 2, 2018
    ChoTimberwolf likes this.
  18. ChoTimberwolf
    Most of the time I let my clipsos start at the middle point, of course only if terrain is good but insta 50 points is sweet yeah gonna try the rasail list next
