stealth and 6th sense
Discussion in 'Rules' started by jackfrost, Sep 25, 2020.
  1. jackfrost
    jackfrost Active Member
    so I'm wondering if you guys can help me figure out if sixth sense actually counters stealth?
    it looks like sixth sense just turns stealth off right?
    that means that your stealth troop walks aup behind my 6thsense troop and I have to ARO dodge because your walking causes and ARO and I can't see you. this means that having 6th sense in ZOC is not good because they just force a dodge ARO then shoot you without consequence ignoring your ability to shoot back? 6th sense used to let you delay in ZOC for this very purpose but I'm having trouble finding that part of the ability.... anyone?
    Good riddance to it. That rule caused so many damned headaches and bad situations.
    Do note that Stealth is Optional, so the Sixth Sense trooper is not more vulnerable for having the skill.
    colbrook likes this.
  3. Tanan
    Tanan Well-Known Member
    The new 6th Sense is godlike. Straight PH roll to move 2” when anything moves in ZoC. No way to bypass this ability.
  4. jackfrost
    ok but you guys are seeing how its worse than it was vs people sneaking up behind you right?
    if someone sneaks up behind you outside of ZOC and they shoot you, you can shoot them back, but if they're in ZOC you will only ever dodge against them... so you've lost the ability to shoot them back in ZOC?
    is that right? that's a nerf to 6th sense... which is fine because it got lots of buffs, but I wanted to make sure that's the weakness
  5. Tanan
    @jackfrost yes, you are correct. 6th sense got a partial nerf.
  6. jackfrost
    hey so since i posted this in several places someone pointed out that you arent restricted from chosing AROs that aren't technically legal.
    so in the above scenario my 6th sense model could ARO shoot, and then if the other model DOESN'T shoot my model then my ARO was illegal and ignored, but if they DO shoot my model my ARO becomes legal.
    this SEEMS to be true only because you only check the validity of the ARO at the last step after both active player orders have occured.
    you can see that by looking at pg 21 in the new rulebook
  7. ijw
    Sort of. The Requirements of a Skill aren't checked until the Resolution Step of the Order, but you still need to follow the rest of the rules for that Skill. And for BS Attacks that involves allocating Burst to targets that are in LoF when you declare the Skill.
  8. obyiscus
    obyiscus Member
    So how would it work if say you had sixth sense and thought someone walking behind you was withing zone of control (but you can't be sure because you can't measure it yet) so you declare a hacking program against them. At the end of their first move they are not inside of ZOC, but then they move for their 2nd skill and enter ZOC. When you declared the hack they were not a valid target for your hacking because they were out of ZOC (just like the reactive player in the earlier post did not have a valid shoot target at the end of the active players first action). But after the 2nd action of the active player they became a valid target, so when the resolution step comes they can be hacked (just like the active player that shoots the sixth sense model in the back would have become a valid target to be shot back).
    In this example would the hack fail because they did not have a valid target when the reaction was initially declared? What if the sixth sense player thinks that they aren't in 8 of the active player after the first half of the order so thinks they have to wait, but then it turns out the active player had been within 8 so they would have had to have declared their order after the first half, and not waited to be shot at?
    DamnDaemon likes this.
  9. jackfrost
    yeah I get that you know the rules and this is the way its supposed to work but by doing it this way you create a lot of finicky possibilities... if it worked the other way it would be very clean.
    its already game breaking that when someone is near a hacking zone you have to guess the ARO which might technically have been illegal in the first place...
  10. ijw
    @obyiscus
    1. You’d check the validity of the ARO during step 5 ARO Check, and find out that you had a valid ARO. In the Resolution step you’d check if you’ve fulfilled the Requirments of the Hacking Program.
    2. This, unfortunately, is where the use-it-or-lose-it nature of AROs kicks in. :-( If you guess wrong, and fail to declare an ARO against the first Short Skill, you’ve lost your chance to ARO.
    @jackfrost
    1. Yeah, I’m well aware of that, but that’s the route CB decided to take.
    2. That’s not game-breaking in N4, you just declare your Hacking ARO and then find out if it worked.
  11. QueensGambit
    @ijw I think I know what you're saying but want to be sure for clarity. This was actually an unresolved question for me in N3 (or it may have been answered but I forgot) so I'm happy to sort it out right off the top in N4.
    1. Active unit activates, spends order, and declares Move. The movement is not in LoF of the reactive unit. The move takes the active unit somewhere close to the reactive unit's ZoC, but we're not sure if it's quite reached it.
    2. Reactive player decides that he thinks the active unit is inside his ZoC. He declares a ZoC ARO (say, Dodge).
    3. Active unit declares a second Move, and moves closer to reactive unit.
    4. N/A, reactive can't declare a new ARO because he has already declared one.
    5. We check, and find that the active unit was NOT in the reactive's ZoC at step 2, but is now in the ZoC because of the second Move at step 3.
    Does the reactive unit resolve a Dodge, or an Idle?
    I'm pretty sure you're saying it's an Idle, because the unit didn't have an ARO at the time it was declared, so it fails step 5. (It would pass step 6 because it now meets the Requirements for Dodge, but it doesn't get that far because it fails step 5 by not having had an ARO at all when declared). Is that right?
    Follow-up question: at step 4, can the reactive player say "I declare Dodge. I realize my declaration may fail because I've already declared an ARO (which was also Dodge), but IF my first declaration turns out to have been invalid, then I will now get a new ARO from your second movement and it will be Dodge."?
  12. ijw
    No. See step 5:
    5. ARO Check: Check that eachTrooper that declared an ARO has been in one of the situations that makes their ARO declaration valid. If they have not, they are considered to have declared an Idle.
    Because the enemy has moved closer, 'has been in one of the situations that makes their ARO declaration valid' is fulfilled.
  13. jackfrost
    and this only works because we are allowed to check LOF but we are not allowed to check distance.
    sigh.
    toadchild likes this.
  14. Ayaxs
    Ayaxs Crane agent, Yuandun division.
    Yes, because else, you could perfectly walk around triggering area for mines, outside hacking areas and ZoC, a little uncertainty is needed for those traps to spring.
  15. wes-o-matic
    wes-o-matic feeelthy casual
    I still think the reactive player should be allowed to measure ZoC of non-null troopers who may have a ZoC (but no LoF) ARO at the point AROs are to be declared (ie after the active trooper declares a skill and any associated movement paths). This could be limited to measuring 8” towards the active model, limited to a single reactive trooper per ARO, requiring the active player to look the other way for a moment, etc. to avoid misuse by That Guy. The whole thing where you play a guessing game based on your ability to eyeball 8 inches, and if you guess wrong you lose your ARO, is both unintuitive and annoying. The game already favors the active turn player plenty, letting the reactive player know clearly whether they do or do not have a valid opportunity to ARO seems like it would be a quality of life improvement.
    “You must do X when Y occurs.”
    “Okay, cool, how do I know when Y occurs?”
    “Haha not telling, you have to guess!”
    “...not cool, bro.”
    DamnDaemon, toadchild and Icchan like this.
  16. ijw
    Except that this has changed in N4, as covered in this freaking thread.
    If you’re expecting a ZoC ARO (because LoF ones are always clear anyway), just declare the ARO and see if it becomes valid.
    Sorry for the exasperated tone, but I’m starting to get irritated at people not bothering to read stuff. :-(
    Hisey and Ayaxs like this.
  17. Marduck
    Marduck Well-Known Member
    hu ... and if the unit is in camo state, when is it that you reveal what trooper it is ?
    Exemple : I move trooper A near ennemi trooper B. Trooper B is in camo state. Player B says "I think i'm in ZoC. I will declare dodge". Does he reveal what is the trooper under the camo marker ? Or do we wait until the resolution phase ? (which may change what player A does with his second skill).
  18. ijw
    When you declare the Skill, as stated in the first Cancellation bullet for the State.
    'The Camouflaged State is cancelled whenever:
    ► The Camouflaged Marker declares an Attack, Look Out!, or any Skill that requires a Roll.
    My emphasis.
    Hisey likes this.
  19. KujakuDM
    KujakuDM Vigilo Confido
    So to confirm a small situation:
    A Camo Marker moves into a 6th Sense Units ZOC but out of LOF.
    6th Sense can only declare Dodge (or reset). Discover & Lookout require LOF.
    Camo Marker does surprise attack, 6th Sense gets to ignore the surprise attack penalty.
    However, Camo specifically mentions this:
    ► When a Trooper in Camouflaged state is activated, each Reactive Trooper can delay the declaration of their ARO until the second half of the Active Trooper’s Order has been declared.
    This doesn't specify that you can only delay if they are in LOF, only that they have to be a REACTIVE trooper, which a 6th sense trooper is, since they ignore stealth.
    With this reading, cant a 6th sense Delay against a camo in ZoC but not in LoF?
  20. QueensGambit
    If it's a camo marker, then I think so, yes. Any time a trooper has an ARO against a camo marker, they can delay their ARO.
    It's not Sixth Sense specific, since camo units don't automatically have stealth anymore. If a camo marker without stealth moves within ZoC of any trooper, that trooper can delay their ARO.
