Greetings! In the starmada sectorial chart you can see that the Lambda Engineer has AVA of 2, and in a separate line the Lambda Doctor has an AVA of 2. But in the Infinity Army they're grouped together in the same profile entry with a shared AVA of 2 and not separated ones with AVA 2 each. Meanwhile there is no mention to Fuzzbots in the Sectorial Chart Image! But in the Infinity Army App the Fuzzbot appears with an avalibity of 2. Maybe there is a typo in the Sectorial Chart? So the duplicated entries of "Specialized Support Unit LAMBDA DOCTOR AVA 2" and "Specialized Support Unit LAMBDA ENGINEER AVA 2" should really be "Specialized Support Unit LAMBDA DOCTOR/ENGINEER AVA 2" and "FUZZBOTS AVA 2"? Thanks lot! :)
I suggest reporting it here: https://forum.corvusbelli.com/threads/infinity-army-7-n4-bugs.37729/ I suspect you are correct, though :)
