Speculative Fire + Targeted + Pitcher
Discussion in '[Archived]: N3 Rules' started by Tanan, May 2, 2020.
  1. Tanan
    Tanan Well-Known Member
    Enemy trooper is in Targeted state. Friendly trooper declares Speculative Fire Pitcher attack against the enemy trooper.
    What happens?
  2. dhellfox
    umm i assume it would be the same as regular spec fire if your targeting the trooper with the pitcher?
    ive never had that scenario happen, i guess its the same but no damage/armor save at the end
    If a trooper in the Targeted state is chosen as the target of Speculative Fire, then the -6 MOD usually applied to that type of Attack is ignored. However, the +3 MOD is still applied.
    #2 dhellfox, May 2, 2020
  3. Tanan
    Where is the Repeater placed?
    Does the enemy trooper make a Guts Roll?
  4. Hachiman Taro
    Hachiman Taro Inverted gadfly
    Pitchers are Targetless so you don't need to have an enemy trooper as a target. You can just target a point on the table near them (they won't get an ARO unless the firer is in LOF / ZOC. nor a guts). The deployable repeater a pitcher fires is only deployable on the game table, not on an enemy trooper.
    It's not as explicit as perhaps it could be, but I think that means you can only fire the pitcher at the game table, and not at an enemy trooper, particularly since the game doesn't give you any rules for what to do if you do fire it at an enemy trooper.
    Savnock likes this.
  5. dhellfox
    i would say it would be placed base to base with the target without a guts as they took no damage. i would wait for someone more familiar with the rules.
    in my head its something like this is happening (timestamp fail 1:42)
    edit: suddenly hachiman taro appears seconds before i hit send XD
  6. Tanan
    @Hachiman Taro I know that weapon has targetless-trait. You probably can use the weapon without it, right? Smoke grenades can target enemy models instead of ground?
    I also know that rules aren’t clearly written in this case. That’s why asked the question.
  7. Hachiman Taro
    There are no rules to use the weapon without it, so I think no. You can't do things the rules where the rules don't tell you what to do.
  8. Tanan
    Targetless. This weapon utilizes a Special Ammunition capable of firing without designating an enemy as a target.
    Can a weapon with this trait target enemies?
  9. Mahtamori
    Part of Speculative Fire requires you to place the target inside the area of effect of the weapon you shoot. Pitchers do not have an area of effect, so you'd have to put the Pitcher's target right on top of the enemy Trooper. Thus, if you hit with the Pitcher, you will not be able to place it. All you'd accomplish is waste orders and Disposable counters.
    I do believe that a smoke grenade would be able to target an enemy trooper (or a Friendly Kuang Shi with an active Biolocator), as a Smoke Grenade is capable of affecting an enemy trooper.
    DukeofEarl, tox, Tanan and 2 others like this.
  10. toadchild
    I think Targetless works better if read to say that you must target a point on the table, rather than that you may.
    In any case, the Pitcher fundamentally doesn't work if you target an enemy model, since that does not result in a legal Deployable Repeater placement.
  11. Grimm
    Grimm New Member
    What happens when you miss? (which seems like it could happen frequently) I can't find any rules on scattering so I am guessing the repeater just falls inert?
  12. ijw
    Correct. N3 Dispersion applies to Combat Jump and Impersonation, but not to weapons.
    Grimm likes this.
