Spec-ops does no count toward unit ava
Discussion in 'Infinity Army' started by Ghost_from_warp, Jul 31, 2019.
  1. Ghost_from_warp
    Ghost_from_warp Classified
    Spec-ops does no count toward unit ava. Bug or feature?
  2. n21lv
    n21lv SymbioHate
    Isn't it technically a different unit? All it has from the Fusiliers are the baseline attributes.
  3. toadchild
    According to the new PDFs and the spec-ops rules on page 211 of Daedalus's Fall, it's a Fusilier with the "Infinity Spec-Ops" special skill.
    n21lv, Ghost_from_warp and colbrook like this.
  4. n21lv
    n21lv SymbioHate
    Hmm, good to know, but where exactly does it state so? I must be blind..
  5. toadchild
    If you look on the PDFs, the spec-ops are listed in the same way FO is. If you look on page 211 of Daedalus Falls it refers to it as a special skill; I can't link to that because it's not on the wiki.
  6. n21lv
    n21lv SymbioHate
    It is on Wiki, actually, and I couldn't find any mention of Spec-Ops being counted towards the baseline trooper's AVA, hence the doubt.
    http://infinitythewiki.com/en/Infinity_Spec-Ops
    Which PDF are you referring to specifically?
    #6 n21lv, Aug 2, 2019
  7. colbrook
    colbrook Black Fryer
    That's a blank page you've linked to.
    The PDF is the Daedalus' Fall profiles PDF that updated all eligible troop types to have a Spec-Op option.
    I've screenshot the Brawler as an example.
  8. toadchild
    The profiles PDF, although currently this format is only used for Brawlers. I recalled it being more pervasive. I don't know if I imagined it, or if I was looking at a different document.
  9. toadchild
    Excellent, thanks! I knew there was another doc.
    4.2 profiles - Brawler only: https://assets.infinitythegame.net/downloads/profiles/en/v4.2/profiles.pdf
    Daedalus profiles - all relevant units: https://assets.infinitythegame.net/...l_profiles/en/v1.0/daedalus_fall_profiles.pdf
  10. n21lv
    n21lv SymbioHate
    @colbrook Right, I guess that's because I got the link from an app I use to view the Wiki. I have fixed the link, so now it leads to the correct page. It's really weird though, as I don't see these profiles for Tohaa Trinomial's Kamaels or Spiral Corps' Taagmas, but I'd also really like to know if Spec-Ops count towards the baseline unit's AVA, since Taagma have limited availability.
  11. colbrook
    Taagma are Page 53 of Daedalus' Fall, Kamael are page 57
    n21lv likes this.
  12. n21lv
    n21lv SymbioHate
    Some of us do not buy all the books, you know :)
    UPD: Oh, I see what you meant. Page 53 & 57 of the PDF..
  13. colbrook
    Yes, the books no longer contain any profiles.
