Hi guys, I've just created a huge set of 3D printable Spaceship Wreckage and wanted to share. Over 210 modular parts all up. You can see more of my designs at www.saucermenstudios.com.au
This is really well done and a great way to add variety to the city-scapes so common in Infinity! Edited to add: now that the Kickstarter is up, I’ve backed to put my money where my mouth is. Very excited to see where this goes!
I've just added a lot mor eoptions to this terrain set and increased the variety for interior set-ups:
Awesome new updates! One question about the interior setups: how easy will it be to remove a higher level to access a lower level for moving around minis inside?
Thanks! Good question. The kit uses the OpenLOCK Clip system, and internal walls are typically all the same size (double height of standard sized external hull piece), so you could not clip the levels together vertically and lift them off as one level, or smaller parts if supported underneath. Larger conencted builds may be trickier to manouver
