    Dismiss Notice
[SOLVED] Move through enemy unconscious trooper
Discussion in 'Solved Rule Questions' started by CabalTrainee, Nov 6, 2018.
  1. CabalTrainee
    Short one just to make sure i'm not doing anything wrong:
    Is there any way to move through/over/under a hostile unconscious trooper?
  2. ijw
    Other than Jump (or Climb if there's a wall in the right place), no. You can Coup de Grâce them, but entering base contact will automatically stop your trooper's movement for the rest of the Order.
  3. colbrook
    colbrook Black Fryer
    If you make contact with an enemy Silhouette your movement ends immediately, Unconscious does not change this.
    You can jump over most prone troopers though.
    Edit: IJW'd
  4. CabalTrainee
    Thank you for telling me i'm still sane.
    PsychoCrane and ijw like this.
  5. HellLois
    As @ijw said ^^
    inane.imp, CabalTrainee and Urobros like this.
