    Dismiss Notice
[SOLVED] Mine AROs Overlapping with Movement Declarations?
Discussion in 'Solved Rule Questions' started by fenren, Oct 29, 2018.
  1. ijw
    As per the Idle rules, yes:
    • The trooper is also considered to perform an Idle when he has declared a Skill not allowed by the rules. In such situation, the ammunition of Disposable weapons or pieces of Equipment is spent, too.
    Xeurian likes this.
  2. Icchan
    Icchan Well-Known Member
    If the mine marker is placed after short skills and ARO's, how could the location be blocked, couldn't I just then put it in another empty spot?
  3. ijw
    No, because you have to say where it's being placed when you declare the Skill.
    fenren and Nemo No Name like this.
  4. HellLois
    yep!
    If the Player declares a Skill and, when he applies its Effects, he realizes the Requirements are not met, then the Skill is considered null. However, the trooper who declared it still generates ARO, as if he has declared an Idle, and loses the ammunition or equipment used, if he declared the use of a Disposable weapon or piece of Equipment.
    http://infinitythewiki.com/en/Order_Expenditure_Sequence
    http://infinitythewiki.com/en/Idle
    ev0k, fenren, Xeurian and 3 others like this.
  5. Ariwch
    Ariwch The denizen of the StateEmpire salt mine
    But on the other hand, the Mine is placed during the same time, and not at the end of the order, which would be when the desired movements trails are indicated on the table. So the movement has no physical location to be drawn!
  6. Mahtamori
    You can argue that one back and forth, as we've done in this thread, but the rule does explicitly state that the mine isn't considered deployed until the end of the order.
    fenren likes this.
  7. Arkhos94
    So, if I understand what was written here correctly, whenever someone ARO by placing a mine, I just need to move in the spot where he choose to put his mine (fully or only partially) to cancel it and change his ARO to idle ?
  8. Robock
    Robock Well-Known Member
    Yes. And on the next order you can Shoot first skill, and then move to where he declared his mine ARO.
    Or you can place a mine where he placed a mine, and both skill will simultaneously cancel (i guess).
    edit to add: in the long run, it will change Mine from a defensive weapon used as last-ditch effort when you know you'll die to an offensive weapon (place it around a corner then move+shoot on the enemy). Still useful as a defensive weapon if you place it during your active turn, but not as a last ditch reaction. Also just as useful as before when you place it in ARO while the enemy is more than 4" away. But that requires to better calculate your placement of your skirmisher when you ended the turn.
    #48 Robock, Nov 6, 2018
  9. Teslarod
    Teslarod Trebuchet Enthusiast
    To summarize this again, what exactly is @Hellois saying?
    1.
    A Move after 'Deploy Mine ARO' declaration can always be used to cancel a Mine by walking into it and turns the ARO into Idle.
    That seems rather.... exploitable. I'd file that under Gotcha moments. But hey dem rules are dem rules.
    Lesh', BLOODGOD and fenren like this.
  10. CabalTrainee
    While very mechanical it does nerf mines a bit. And those are predominant in the midfield right now. No idea yet if that is good or bad.
    fenren likes this.
  11. Sabin76
    ... at least until the powers that be decide which it is, as they have done in this thread :).
    Robock likes this.
  12. fenren
    fenren Active Member
    @HellLois Thank you for the final clarifying answer. I really appreciate the active engagement to get official rules answers out to the community.
    To those who joined in the discussion: I think this significantly lowers the value of midfield mine-layers on dense tables. For me, it will result in fielding them less often and changes how I play them. But at least we know now, and that's good enough for me!
    #52 fenren, Nov 6, 2018
    HellLois and Robock like this.
