Hi guys and gals, I can not find a defintive answer for the interaction of stealth and sixth sense. Can someone explain it or point me to the correct thread? I asume that sixth sense cancels the stealth + shoot out of LoF part. But does it outright remove the stealth while in a ZoC? Also, when a trooper with stealth tries to stealth trough a repeater, and a hacker has sixth sense, can the hacker react regardless, since sixth sense kind of cancels stealth under that circumstance? Thank you very much!
Stealth has no effect against a trooper with 6th Sense, this is part of the Stealth rules so isn't bound by any 6th Sense requirements. This includes trying to Stealth through a repeater's hacking area, because Stealth does not work against troopers with 6th Sense. https://infinitythewiki.com/Stealth
Note that it states "Troopers with the Sixth Sense special skill" and not "Troopers using the Sixth Sense special skill" (emphasis mine)
Can you clarify that? I guess a link team hacker will not nullify the stealth skill, just a unit that actually has the skill on his profile?
No. What @colbrook means is that you don't have to trigger the requirements of Sixth Sense (i.e. be the target of an attack) for it to negate Stealth.
