    Dismiss Notice
Shooting at unconscious model
Discussion in 'Rules' started by Ramas, Aug 24, 2019.
  1. Ramas
    Ramas Member
    Hey guys, I have a basic question. Some people say that you can't shoot at unconscious models. This doesn't make sense to me. Can you help me out? Where I can find something to this topic in the rulebook?
  2. Hecaton
    Whether a trooper is unconscious or not has no bearing on whether you can shoot at it. Keep in mind that Unconscious models fall prone, if able, however, so if a trooper is standing behind a wall and falls unconscious it frequently will not be able to be shot from the other side of the wall. Also it's good to be aware that skills like Mimetism, Total Immunity, etc stop working when the bearer is Unconscious, though Cover still applies.
    MikeTheScrivener and Ramas like this.
  3. ijw
    There is nothing in the rulebook, because no such rule exists.
    chromedog and Ramas like this.
  4. Ramas
    Ramas Member
    But if an unconscious model is for example effected by a template weapon. What happens then? So we have only the rule for coup de grace. That makes absolutely no sense. If someone stands not far from the unconscious model why he can't shoot at the lying body. You can shoot at the model also with a Medikit. Consequently you must have the possibility to shoot in generel at an unconscious model.
  5. Yvain
    Yvain Well-Known Member
    You can shoot an unconscious model. The unconscious model loses most of its defensive abilities, but otherwise acts as a normal prone model.
    You shoot as normal and the unconscious model makes an arm or bts save then lives or goes full dead.
  6. Ramas
    Ramas Member
    So we can derive this out of different rules as usual. But how can we explain this for new players which say:"There is no explicit rule. You can't do this." But from which rules we can derive the results. I am not convinced at this point.
  7. ijw
    chromedog and MikeTheScrivener like this.
  8. Ramas
    Ramas Member
    The rule says "target". We have no definition in the rules of target. The model can be the "target" of a medikit. Look at the rule. http://infinitythewiki.com/en/Medikit This means an unconscious model can be a "target". Other argumentation is inkonsequent. If we have a rule gap here we have to fill it. There is no sign that CB doesn't want that you can't shoot at an unconscious model. A template can effect an unconscious model. The interest here is not the same as by using a medikit. The use of a medikit is no attack. But the use itself is similar to shooting at a target. And the medikit rule speaks of "target". And this is a similarity. Consequently you have to say that shooting at unconscious models is not impossible.
  9. ijw
    Yes. Nobody here is arguing against this. You can shoot Unconscious enemy troopers.
    Anyone saying that you can’t will have to provide a rules argument saying why it wouldn’t be possible.
  10. MikeTheScrivener
    The requirements section of each skill usually defines to us what a valid target for that particular skill may be.
    Using your example of Medikit:
    - they have to be an unconscious friendly trooper
    With BS attack the only requirement is that we need LoF, and we know its an "Attack" meaning that we cannot declare it on friendly or neutral troopers. an enemy in the Unconscious state is neither of those things.
  11. Yvain
    http://infinitythewiki.com/en/Unconscious
    Try looking at the rules for Unconscious state. This is all that changes for an unconscious model:
    1. Goes auto prone
    2. Can't activate
    3. Can't generate orders
    4. No auto skills or auto equipment
    5. Count as a casualty
    Functionally, it is just a regular model that is degraded. As such anything that can normally effect the model can be used. Does that maybe answer what you were asking?
    Ramas likes this.
  12. Ramas
    Ramas Member
    Perfect! Thank you for your good answer :-)
