    Dismiss Notice
Shasvastii in ITS Mission: Acquisition
Discussion in 'Combined Army' started by John Benford, Feb 18, 2020.
  1. John Benford
    John Benford Member
    I have a tournament coming soon where I have to play Acquisition.
    This throws up the conundrum of who to be the Liaison Officer and the Data tracker.
    Shasvastii Expeditionary Force
    [​IMG]10
    SPHINX Spitfire, 2 Heavy Flamethrowers / EXP CCW. (2 | 106)
    [​IMG] SCINDRON Flash Pulse / Knife. (0 | 0)
    GWAILO Lieutenant HMG / Breaker Pistol, Knife. (2 | 45)
    M-DRONE FTO (Nanoscreen) Combi Rifle / Electric Pulse. (0 | 23)
    CALIBAN Engineer Submachine Gun, Pulzar, D-Charges / Pistol, Knife, CC Weapon. (0 | 28)
    MED-TECH OBSIDON MEDCHANOID (Journalist L1) Submachine Gun, D-Charges / Pistol, Knife. (0 | 22)
    SLAVE DRONE Electric Pulse. (0 | 3)
    SEED-SOLDIER Combi Rifle, D.E.P. / Pistol, Knife. (0 | 16)
    IKADRON (Baggage, Repeater) 2 Light Flamethrowers, Flash Pulse / Pistol, Electric Pulse. (0 | 9)
    4 SWC | 300 Points
    My thoughts are:
    * Do I use the Sphinx as my data tracker? This does take a lot away from not being able to go into CAMO and not starting in hidden deployment. It is still a TO TAG that has ARM 6 and can be put into suppression. Not sure if it will still survive until round three - it has a big bullseye!
    * Second alternative is to make the Gwailo Lt with HMG my data tracker. Use the Albedo to get rid of visors who are threat to the Sphinx. The M-drones will be useful in sensoring the middle to flush out TO hidden enemies.
    * The Caliban engineer and the Malignos killer hacker have the bonus of +3WIP and having the chance of rolling two dice. The Malignos will likely come out during turn 3 and hopefully survive and control a console.
    * Dr Worm and Caliban engineer are there to help repair the Sphinx when it loses structure.
    * Ikadrons are cheap order support and there to protect my flanks from AD:combat jump troops.
    * The seed-soldiers are there to provide chest-mines near the two consoles.
    * The problem I see is that I have no FO for the Liaison Officer. I suppose I could substitute one seed-soldier for a Nox FO.
    * I miss the idea of having four plus taigha miniatures causing harassment straight away due to the 16" deployment.
  2. Freki
    Freki Well-Known Member
    Hey John, there is no Malignos in your list
  3. John Benford
    John Benford Member
    whoops your right! No malignos. Can’t have everything.
    what do you think of my list?
  4. Freki
    Totally out of my depth here since I've never played them.
    But I'll try some constructive critism:
    - Lt is fairly obvious, 2 markers not prone and 1 other camo
    - No Dazer to work with your Multi Terrain TAG
    - Little ARO
    - Gwailo haris comes with a large repeater network
    Why not replace this
    [​IMG]3
    2 SWC | 91 Points
    With this
    [​IMG]3
    SHESKIIN Lieutenant Red Fury, Pulzar, D-Charges / Breaker Pistol, EXP CC Weapon. (2 | 66)
    NOX Combi Rifle + Light Grenade Launcher (Normal and Nimbus plus) / Pistol, Knife. (1 | 17)
    NOX (Forward Observer) Combi Rifle, Zapper / Pistol, Knife. (0 | 15)
    3 SWC | 98 Points
    You get your FO, you drop the extended hacking zone and even get some extra utility with a nimbus plus or the opportunistic grenade on clumped up troops.
    #4 Freki, Feb 18, 2020
    Teslarod likes this.
  5. John Benford
    John Benford Member
    I like the idea of the grenade launcher with nimbus plus grenades. With help the Sphinx with flaming enemy miniatures.
  6. Bruno Braga
    Bruno Braga Well-Known Member
    [​IMG]10
    SHESKIIN Red Fury, Pulzar, D-Charges / Pistol, DA CCW. (1 | 54)
    NOX MULTI Sniper / Pistol, Knife. (1.5 | 21)
    NOX Hacker (EI Hacking Device) Submachine Gun, Zapper / Pistol, Knife. (0.5 | 17)
    NOX Lieutenant Combi Rifle, Zapper / Pistol, Knife. (0 | 14)
    SHROUDED (Minelayer) Boarding Shotgun, Dazer / Pistol, Knife. (0 | 24)
    5 SWC | 297 Points
  7. John Benford
    John Benford Member
    Didn’t think about the problem of the hacking net. Be nice to have sensor though.
  8. John Benford
    John Benford Member
    I try and avoid Sheskiin in a five man fire team. Trying to advance so many miniatures up field is cumbersome. Can be a liability. Prefer a Harris
    Lesh' and Bruno Braga like this.
  9. Bruno Braga
    Yeah I much prefer her in a Haris, she also doesn't really need the BS bonus, tends to be overkill in my opinion. But a simple Haris like this:
    [​IMG]10
    SHESKIIN Lieutenant Red Fury, Pulzar, D-Charges / Pistol, DA CCW. (1 | 54)
    CALIBAN (Chain of Command) Submachine Gun, Pulzar, D-Charges / Pistol, Knife, CC Weapon. (0 | 29)
    R-DRONE Flash Pulse, Sniffer / Electric Pulse. (0 | 8)
    4.5 SWC | 300 Points
    SoEinBasti likes this.
  10. essexdave
    essexdave Well-Known Member
    Hi John!
    Have you thought about swapping the Gwailo to the MSV2 HRL LT option, drop both the M-Drones and grab a Caliban Chain of Command, add a Nox Forward Observer and a slave drone. The Sphinx can well do the heavy lifting that you'd no doubt planned for the Gwailo HMG and I find the HRL is better for AROs being a pretty tough nut to crack and capable of dealing with two of the big Sphinx threats: warbands and MSV.
    Also gives you the liaison officer.
    ED
