    Dismiss Notice
Scenery Items and Objective Rooms
Discussion in 'ITS' started by kghamilton, Mar 12, 2019.
  1. kghamilton
    kghamilton Member
    Hi there,
    Question regarding destroying scenery items, specifically what happens when you destroy a wall of an objective room.
    Excerpt from the wiki states:
    The third bullet point states LoF may never be drawn through a narrow access point created by the destroyed state. But since it is still an access point and can be walked through, is there anything stopping a player intuitive or spec firing through to the other side?
    Thanks in advance
  2. inane.imp
    Intuitive Fire still requires LOF (that LOF can be obscured). So I would say that you can't.
    Spec Fire just needs an opening. So I would say that you can.
  3. solkan
    solkan Well-Known Member
    Look at the rules for intuitive attack. It specifies:
    Access points aren’t zero visibility zones.
    But note that the bullet points suffer from CB’s chronic organization problem. Destroy a wall and you place a gate marker along the wall. Destroy the whole building and it turns into a saturation zone (which you can draw line of fire through). Presumably when you do that after doing so much damage to the various parts of the building. :-/
  4. inane.imp
    Building isn't replaced when it's destroyed. The Sat Zone Effect is added.
    chromedog and ijw like this.
