    Dismiss Notice
Rulebook errors
Discussion in 'Rules' started by piecoo, Nov 26, 2017.
  1. piecoo
    piecoo New Member
    This is repost from BGG.
    Hi.
    Correct me if I am wrong.
    I have found small issues in rule book.
    1. It's not that obvious explained that critilcal succsess [(*)] is counted as damage during Attack. Green die critical shield is explained properly in Reference booklet.
    2. Line of sight example on p.12 has small error with verticies marked as obstructed but they are not. It does not change black dice acusisition.
    3. Blue die in rule book was changed after rulebook was created. There is no side with (*)(!) there is only (*) on that side.
    Luisjoey likes this.
  2. evert
    evert New Member
  3. -V-
    -V- A! Team member
    We'll check those issues. Thanks a lot!
    :wink:
  4. Pierzasty
    Pierzasty Null-Space Entity
    Illustration that shows moving Mushashi is missing a barrier that should be there in that map configuration. I'll post a pic later.
  5. -V-
    -V- A! Team member
    We'll check that. Thank you!
  6. HarlequinOfDeath
    Old thread but for clarification @-V-:
    On page 12 of the rulebook there are five lines in the left line of sight example. Let us call them 1 to 5 from left to right.
    Shooter is Wild Bill, target is Hexxer:
    1+2 give no LoS.
    3 doesn't give LoS as well in my opinion (because of the blocked space it is touching) but has a circle which makes some players in my meta think there is LoS in similar gaming situations. (But you can draw from another point of Wild Bill a LoS to that spot by the way.)
    4 gives LoS, but is marked as no LoS.
    5 gives LoS.
    #6 HarlequinOfDeath, Oct 22, 2019
  7. Croepoek
    Croepoek Well-Known Member
    Also Reference Guide page 2 (1.7 from Download section) -Actions: The explanation for :5: has a :6: symbol. So two times :6: shows up giving contradicting info. See screenshot.
    Rodro and AdmiralJCJF like this.
  8. Rodro
    Rodro Member
    Warcor Aristeia
    Croepoek and AdmiralJCJF like this.
  9. Croepoek
    Yes good point. Also interesting that the Spanish version is correct. So probably only a „typo“ with using the wrong symbol. But I think still noteworthy so future prints and the pdf can be corrected easily :)
