Question about Mary Problems' miniature.
Tema en 'Miniatures' iniciado por Pettynyt Pelaaja, 26 Oct 2020.
  1. I am thinking of acquiring this miniature to use it as a proxy for another troop by making a small transformation, but I would like to know if the submachine gun that leads to the back is fixed or is a separate piece (basically the transformation would be to change that weapon for another one).
    #1 Pettynyt Pelaaja, 26 Oct 2020
    Última edición por un moderador: 26 Oct 2020
  2. Sicaris
    Sicaris Active Member
    15 Dic 2018
    It should be very easy. She's 2 pieces, the SMG and everything else. Out of curiosity what are you going to proxy her for?
    A Golem2God le gusta esto.
  3. Golem2God
    25 Nov 2017
    I looks like it is separate from the body & needs to be glued on. I had one fo the newer models that had a similar set-up with a weapon placed on the back & the weapon came as a separate piece.
  4. Thanks for the answers.
    The idea is to replace the submachine gun with a combi rifle and with that small change transform it into Valerya Gromoz :yum:
    One more question, now that I look at it, I don't know if it will be the effect of the photography, but don't the arms seem a little strange? Too thin?
    #4 Pettynyt Pelaaja, 27 Oct 2020
    Última edición por un moderador: 27 Oct 2020
  5. colbrook
    Part of it is white sleeves against a white background, part of it is that she's a skinny teenage-ish hacker.
  6. :+1:
    Thanks for the answer.
  7. Other candidates to be Valerya Gromoz are these:
    (except perhaps for rabbit ears)
    (and with this one I am doubting between Varerya Gromoz or a teenager REM Driver)
    #7 Pettynyt Pelaaja, 27 Oct 2020
  8. toadchild
    22 Feb 2017
    Defiance had an updated Gromoz figure in one of the expansions, so I’m hoping that means a general release resculpt is also in the pipeline.
  9. Yea, I know that expansion. Of the four miniatures the expansion brings ... I really don't know which one I like the most. :thinking_face:
    But I suspect it will take a while for us to see them released for infinity. :cry:
    #9 Pettynyt Pelaaja, 28 Oct 2020
    Última edición por un moderador: 28 Oct 2020
    A Golem2God y toadchild les gusta esto.
  10. Catspaw
    Catspaw Well-Known Member
    29 Jul 2020
    Here's who I'm using for Valerya...
  11. toadchild
    22 Feb 2017
    I only ordered the base game, so I'm holding out for general releases for both Gromoz and Kendrat.
  12. A good alternative, yeah.
    Although for me Isobel's miniature has the same problem as Valerya's miniature... I don't like squatting (I don't know if it's the right word) poses at all.
    #12 Pettynyt Pelaaja, 28 Oct 2020
