Question about AI beacons
Discussion in 'Combined Army' started by BrianJ, Apr 21, 2019.
  1. BrianJ
    BrianJ Well-Known Member
    Hi guys, new OCF player here trying to get up to speed with all the fancy options the EI offers from my previously played Haqqislamites.
    I've immediately run into a confusing issue with Imetrons in the first round of our local grow league. When they disperse and stay on the table, however, they cannot be placed in the location where they dispersed (on top of another trooper, edge of a building, non-level surface etc.). What happens?
    It seems pretty clear in the rules for AD that a trooper would then be placed on your DZ edge. Now with the FAQ clearly stating that beacons behave differently than troopers when they disperse into an enemy DZ (they stay there) I don't know how to interpret when Imetrons are considered 'troopers' vs when they are 'equipment'.
    Currently I've been just calling them 'destroyed' due to the wording that an AD trooper which disperses to an unplaceable area and thus must be placed on the edge of a DZ 'loses all equipment deployed with it'. I'd sure like to get a firmer ruling from some veteran servants of the EI.
    Hope you guys can share your experiences!
  2. Hecaton
    I've always played it that it gets bounced back to your DZ. Honestly the FAQ ruling doesn't make much sense.
  3. BrianJ
    Both seem pretty reasonable to me, and it does seem like them being destroyed is pretty heavy handed. Have you encountered significant contention with your playing it as the DZ edge deployment in a tournament match or anything?
  4. toadchild
    Can you point me to which rule about losing equipment you're referring to? The closest I can find is this, under infiltration:
    Additionally, after failing an Infiltration Roll, the user loses the option to deploy in Camouflaged or TO Camouflaged state and the Hidden Deployment option granted by the Camouflage and Hiding (CH)Special Skill, as well as any Deployable Weapons and Equipment deployed alongside him, which are removed from the game table.
    That's specifically for things like minelayers and crazyokoalas; if you were trying to put deployables ontot he opponent's half of the table but fail the roll, they are removed.
    chromedog and Hecaton like this.
  5. toadchild
    Anyway, I'd probably go with either booting it back to the edge of the DZ or minorly fudge the distance if the model disperses to somewhere immediately adjacent to a legal landing zone.
    WarHound and Hecaton like this.
  6. BrianJ
    Yes, that was the rule I was was recalling and thinking it was for both impersonation and AD dispersion, my mistake. Thanks for your advice!
  7. Bohrdog
    Bohrdog Santathematics
    Yeah they work just like AD troops in every way but they can land in the enemy DZ. That is the only difference.
  8. Sabin76
    There's also the fact that you lose them if they disperse off the table...
  9. Hecaton
    Yes, but we have to assume that every exception to the rules must be clearly stated out. Prior to that FAQ ruling they got bounced back to your DZ if they landed in the enemy DZ as well; I'm guessing that they don't really play by the rules at CB so they just were like "of course it works this way!" when they wrote that FAQ.
    Nemo No Name likes this.
  10. Bohrdog
    They are the rules how could they not play by them. The bounced back to the DZ is why they changed it because there should be some risk to getting a 4pt regular order.
  11. Hecaton
    It's in the FAQ, though, and isn't presented as a change, so it comes off as a high possibility that CB just doesn't play by what's written in the rulebook and issues FAQ rulings based off of "feel." Or they took the advice of WarCors who have opinions (and only 2/8 factions have AI beacons, so cries to nerf them will likely have 80% support).
    Dragonstriker and Ginrei like this.
  12. xagroth
    Dropping AD troopers or AI beacons on top of buildings with unlimited Height (like the central Control Room) makes them act as if they went out of the table, so AD troopers go to a border in your DZ while AI Beacons are destroyed.
  13. DukeofEarl
    DukeofEarl Well-Known Member
    75 % by that math ;)
  14. joedj
    joedj Member
    From wiki "Troopers using AD cannot deploy....in base to base contact with...piece of scenery." That dispersion roll is particularly brutal on Imetrons if a failure results in landing on a piece of scenery in our scenery dense battlefields. If "cannot", does that mean it is completely lost? Or does it mean it bounces back to deployment zone? If completely lost, it would be harsh, risking a Combat Group slot (Limited Insertion?) and an Order slot for an non-interactive model.
    Does AD:Combat Jump include all other lesser levels of AD? Like many/most abilities?
    If yes, Imetrons may also be deployed, safely, in one of the 8 segments on table edge as described by AD:Parachutist
  15. CAnon
    CAnon Well-Known Member
    Yes, however:
  16. Dragonstriker
    @joedj Furthermore, “cannot deploy in base to base contact” means “cannot claim cover” not “cannot be placed” per the most recent FAQ.
  17. toadchild
    Do you mean this one?
    Troopers using Airborne Deployment cannot deploy Prone or in base to base contact with another troop, Marker, mission objective, or piece of scenery. Does this means that a troop can not deploy on a rooftop because the troop will be in contact with a piece of scenery?
    You can deploy on a rooftop. When the rule says that the troop cannot be deployed in contact with a piece of scenery, this means that the troop cannot gain cover from that piece of scenery. ​
    I'm pretty sure this is addressing the old "does a roof of a building count as scenery?" question. You should still place AD models at least 1 mm separated from any pieces of terrain when dropping them in (whether your intended location or as a result of scatter).
  18. xagroth
    Yeah, but I doubt the idea is to force you to discard the AD trooper or send him to your DZ if he happens to land precisely on the corner of a building (unable to stand there), else people will try to force to play in sparse tables to be able to play AD troops... or not play those at all.
  19. Dragonstriker
    Yes. It also covers landing on a roof with other features or on top of crates etc, since people have argued in the past those are scenery items not the table surface. Base to base contact in this context has been clarified to mean laterally -to claim cover or to interact- not “placed on top of”.
    chromedog and toadchild like this.
  20. toadchild
    Ok, sounds like we're on the same page. I had initially read your previous comment as being much more permissive about base contact with actual cover-granting terrain.
