When I print an Army list with the Code One Army Builder it prints out very small, can't seem to find a way to make it print big enough to read. Any help?
Here is a picture of my screen I can see a bit of the list, but it is behind my desktop on the left with no apparent way to bring it forward.
Maybe maximize the window with the army list? That works for me. What you are seeing is a pop-up window of what the printed page will look like, only it has weird dimensions for some reason. If you actually print it to pdf, the pdf will open up just fine.
Thanks, I'll try printing to a PDF and see how that works. It does actually print the army list but you need a magnifying glass to be able to read it. I tried several different settings on the printer, but nothing seemed to work. The small portion of the list that shows on my screen only pops up when the printer info is active and I can't make the list do anything. I need to try doing it home also, may have something to do with our system here at work.
This is what I get either direct to the printer or as a PDF. See attached. What is the ctrl+F5 and when and where do it.
It reload the page clearing the cache memory. BUT!!!! It seems you have some weird settings on the PDF writer. Set page as vertical (portrait?). Now it should be as Landscape.
Not sure what is going on, I think it might have something to do with our system here at work. Does not matter if I do landscape or portrait it just prints it small up in the corner of the page. I'll give it a try at home and see what happens.
I had an HP 401 laser at my old job that would randomly do a similar thing with PDFs from certain sources, fixed or worn a firmware update on the printer itself.
