Points for Dominate ZO with Zondnautica or Tomcat
Discussion in '[Archived]: N3 Rules' started by daszul, May 24, 2019.
  1. daszul
    daszul Well-Known Member
    Am I correct,
    that dismounting from a Zondnautica's Zondmate adds 5 points to your sum for Dominate ZO,
    or do I have to subtract them from points of the 'main' profile?
    Zoe & Pi Well, or the Überfallkommando have their points listed separately,
    with a sum that you 'buy' in the army builder.
    But the Zondnautica don't, neither do Carlota & Moriarty or any other Tomcat.
    So it's 'free 4 or 5 points' for Dominate ZO?
    Edit: If you print it, there are only points listed for the mounted Zondnautica?
    #1 daszul, May 24, 2019
  2. Cartographer
    FAQ has the answer:
    Q: How are troopers with G: Servant and G: Synchronized counted for Dominating Zones of Operations, Killing and Victory Points?
    A: Troops with G: Servant have their own cost in points and that is the value that is used to count Victory Points, Killing or points for Dominate a Zone. In the case of troops with a G: Synchronized or G: Servant trooper included in their unit entry, break down the points cost for each trooper. For example, an Auxilia and its Auxbot cost 14 points, but the breakdown of points indicates that the Auxbot costs 4 points, which are part of the 14 points of the Synchronized Unit, so the Auxilia costs 10 points. So, if both are in the same area to be controlled, the Synchronized Unit would add 14 points (not 18) and if they are in different areas you would have to count 4 points in one area for the Auxbot and 10 points (14-4) by the Auxilia in the other area. It works in the same way for calculating Victory Points and Killing.
    Hecaton, daszul, Robock and 1 other person like this.
  3. Ben Kenobi
    Ben Kenobi Well-Known Member
    You have to subtract the 5 points from the value
    daszul likes this.
  4. daszul
    Oh I see, AI-Motorcycle states that it is Ghost:Synchronized.
    Thanks!
