    Dismiss Notice
Pitcher and Smoke special Dodge burst bonus into saturation zone
Discussion in 'Rules' started by Tanan, Jul 20, 2020.
  1. Tanan
    Tanan Active Member
    3-man fireteam fires a targetless non-speculative fire pitcher (or a smoke grenade) into a saturation zone. Is the BS roll made with one or two dice?
  2. colbrook
    colbrook Black Fryer
    One as the BS Attack has it's burst reduced by one due to the Saturation Zone.
    Targetless means you can target a spot on the ground instead of an enemy, but it doesn't mean there's literally no target.
    Edit: In your Active turn you can target two separate spots at burst one each, effectively getting around the Saturation Zone.
    #2 colbrook, Jul 20, 2020
  3. Tanan
    Tanan Active Member
    Yes, but are pitcher and smoke grenade “BS Attacks”?
    There is are multiple threads about Special Dodge not being an attack. Pitcher says that you can place a Repeater by passing a BS roll. Perhaps these are “BS attacks”.
    For example, you can deploy two mines in a saturation zone, because they aren’t BS attacks. From a fluff point of view, I can see how that only small objects like bullets are affected by the saturation zone.
  4. colbrook
    They are still BS Weapons that use the BS Attack skill, yes.
    Edit: Grenades have the Throwing Weapon Trait, but are still essentially BS Weapons.
  5. Papa Bey
    The +1 burst rule requires they be BS weapons.
    Boy have I been doing this wrong. Who knew that mines were "BS weapons".
  6. colbrook
    Yeah, I missed that, Fireteam bonuses don't let you deploy extra mines,
    Though you do get a +1 Burst for Drop Bears or Mine Launchers being used as a BS Weapon, those would also be affected by a Saturation Zone.
    Tanan likes this.
  7. Tanan
    Tanan Active Member
    What if the attacker splits his burst by targeting two different spots (0,000001mm apart to be exact) on the ground?
  8. colbrook
    In the Active turn, that's fine (though for Pitchers I'd advise choosing targets at least 25mm apart so both have space to be placed)
    In the Reactive turn that's not possible as you must target the same spot with your full burst.
    inane.imp and Tanan like this.
  9. Tanan
    Tanan Active Member
    Is that mandatory?
    Also the placement rules for Pitcher repeaters aren’t precisely written. For example, does the pitched repeater token need be centered on the target spot?
  10. colbrook
    Targeting the same spot in ARO? Yes, everything that lets you increase the burst of a BS Attack also includes language forbidding you from splitting the burst.
    This has been discussed https://forum.corvusbelli.com/threads/link-team-burst-bonus-and-placement.26005/page-3 I tend to agree with IJW's position that it's deployed centred on the target as it's the most consistent with the rest of the ruleset.
    Tanan likes this.
  11. inane.imp
    This page:
    http://wiki.infinitythegame.com/en/Types_of_Weapons
    If it performs a BS Attack and is a Weapon then it's a BS Weapon.
    This means that Drop Bears, Pitchers and Mine Dispensers et al are all "BS Weapons" for the purposes of Fireteam Burst bonuses.
