Parachutist and combat jump and confused deployment
Discussion in '[Archived]: N4 Rules' started by Ruaridh, Apr 22, 2021.
  1. Ruaridh
    Ruaridh Well-Known Member
    Are these Two skills effected by confused deployment as they are not deployed at the start? If so and they fail the roll how do they deploy?
    Sent from my SM-G973F using Tapatalk
  2. JoKeR
    JoKeR HAWZA Instructor
    well, it all explained in a Confuse Deployment rule from a ITS.
    Yes, both skill is a Deployment skills, both let you deploy outside your Deployment Zone & therefore is affected by this rule, if you use them outside own DZ.
    Both Parachutist or Combat Jump user must make PH -3 Roll in a moment you try to deploy them. Remember that Combat Jump may have additional Modifiers (for example PH=X or another positive or negative MOD, which you ALSO must take to account). Parachutists still restricted by boards edges & NOT in enemy DZ.
    in case of Yuan with [PH=11] & also working program Controlled Jump on Allied EVO it would be
    PH 11 (trooper rule) - 3 (Confused deployment) +3 (EVO program) = 11
    if a roll is failed - such a unit must be deployed in his own Deployment zone (you NOT NEED touch board edge, as normal, cause Confused deployment change it, but your landing penalised in most cases by -3 MOD & also with the fact that losing a roll you land right into Biotechvore area)
    chromedog, inane.imp and Ruaridh like this.
  3. Ruaridh
    Thank you. Yes I read the rules on comlog. It just seemed weird that could be placed.anywhere in deployment for the failed parachutist roll, which is mainly what I was wondering about but thought worth checking for both :)
  4. paddyBatman
    paddyBatman New Member
    Sanity check, without confused deployment, does the use of parachutist require a roll?
  5. Tristan228
    Nope
    paddyBatman likes this.
