Old forum closing / Cierre del viejo foro
Discussion in 'Forum Feedback' started by Koni, Jan 28, 2019.
  1. Koni
    Koni BanHammer
    Good morning guys,
    We announce you that we'll close definitely the old forums http://infinitytheforums.com/forum/ the next monday.
    As we said in November 2017, the forum remained in read mode only for some months, and now is time to close it. So, if you have something you want to save, you have the last 7 days.
    Saludos foreros,
    Os anunciamos que los viejos foros se cerrarán definitivamente el próximo lunes http://infinitytheforums.com/foro/
    Como dijimos en Noviembre de 2017, los foros se han mantenido en modo de lectura por unos cuantos meses, pero ahora es el momento de cerrarlos del todo. Así pues, si queréis rescatar algo, tenéis 7 días hasta el cierre.
    Golem2God and Koin-Koin like this.
  2. FatherKnowsBest
    Booo.
    Old forum was best forum.
    m2cat, Dragonstriker and Pierzasty like this.
  3. Pierzasty
    Pierzasty Null-Space Entity
    End of an era.
  4. Zewrath
    Zewrath Elitist Jerk
    So how will this affect the only justification of going Prone with anything else other than the Move skill, if we no longer have access to Palanka's ruling?
  5. Pierzasty
    Says you. I have at least 3 backups, 2 are offline, 1 is protected against EMP.
    No, forum backups are not important enough to warrant protection against direct nuclear strikes.
  6. oldGregg
    oldGregg Well-Known Member
    Can we just copy it over here?
  7. n21lv
    n21lv SymbioHate
    TL;DR: NO.
    Longer, boring and somewhat technical answer follows below.
    Old forum is built upon IPB (Invision Power Board), which is a quite well-known proprietary forum engine. This forum is built upon XenForo, which seems to be a less-known forum software. The biggest issue is that most forum engine database structure are so vastly different, that transferring forums from one engine to another becomes a very tedious and resource-demanding task. Specifically, you would need to transform all tables (users, access rights, forum structure, message structure etc) onto totally different rails. Think of this like planning to build a house on a flat area with perfect ground with no ground water at all, and then suddenly having to change all that because it turns out you bought a land plot that is basically a rocky swamp located next to a mountain. Then you would need to check that everything actually transferred properly, that there are no orphaned records (referenced somewhere in the past, but their reference to the 'parent' record was broken, hence the name), that permissions are transferred properly so regular users don't suddenly have admin permissions etc.
    I have tasked myself once with creating a website + forum for our local LARP/HEMA club and initially thought I could transfer old forum data to the new rails, but after evaluating the task more thoroughly, I abandoned the idea. Too much time to spend with little to no gain.
    Golem2God and eciu like this.
  8. oldGregg
    Yeah, no. I meant; why not literally copy-paste the ruling here if its so important? I get that the forum isn't worth migrating.
    FatherKnowsBest and Golem2God like this.
  9. n21lv
    n21lv SymbioHate
    Question is, why don't CB put more meaningful Q&A into FAQ and update it more frequently than once a year? I mean, even Gee Dubbyou addresses their FAQ better these days..
  10. oldGregg
    Not ever gonna catch me arguing against that!
    n21lv likes this.
  11. Triumph
    @Koni could I reccommend you guys go and save any rulings palanka made for the community to refer to? Will save @HellLois the work of needing to make the rulings all over again.
  12. Section9
    Seconded, a lot of the N3 rules questions are on the old forum, not here on the new forum.
    Robock, FatherKnowsBest and Golem2God like this.
  13. n21lv
    n21lv SymbioHate
    Or you can incorporate them into a FAQ ;)
  14. Pierzasty
    Nah, that would be reasonable, can't have that.
  15. Pierzasty
    And the old address gives a DNS error.
    Good night, sweet forums, and flights of Caskudas sing thee to thy rest.
    FatherKnowsBest likes this.
  16. Section9
    Until the Caskudas landing and Exploding wake you up!:innocent:
  17. FatherKnowsBest
    Like:
