[N5] Q&A Discord for rules by IJW
Discussion in 'Rules' started by Wizzy, Jan 2, 2025.
    Here's a topic to index the questions & answers that take place on the discord that IJW does also known under the speudo of Ian James 007 Wood and who works on the rules as an English-speaking proofreader/tester/cake taster/..., which may therefore be worth pre-FAQ of Infinity N5.
    I've added the dates of the answers to help you know which rules version they refer to.
    chromedog and bladerunner_35 like this.
    CLIMB
    17/12/24 [13:52] Ian James Wood: No it doesn't. A vertical surface is still 'a surface'.
    Q: Declaring climb. It used to in n4 afaik
    17/12/24 [21:54]Ian James Wood: I suggest looking at the N5 Cancellation clauses for Marker States.
    SUPPRESSIVE FIRE
    Q: so you CAN sf something and have it rejoin the link in sf at end of turn?
    17/12/24 [22:37]Ian James Wood: No. At least, not rejoin and stay in SF State.
    See rule : "The trooper join any fireteam"
    SPEEDBAL
    Q: Speedball + Controlled Jump is a fun one
    17/12/24 [22:39]Ian James Wood: You can assume that I have a list of pretty well all rules issues that have been bought up so far. EDIT and a few that haven't been bought up/spotted yet.
    CAUTION MOOVE
    Q: yall the second bullet of stealth is getting around the second bullet of cautious move reqs to allow stealth HI to Cautious through hacking area right?
    "- When a Hackable Trooper in Model form declares Cautious Movement, it must begin and end at two points on the game table that lie outside of all enemy Hackers' Hacking Zones."
    17/12/24 [13:17]Ian James Wood: If they have Stealth they can just Move instead.
    Q: there are times when you want to cross a gap with repeater coverage
    [13:19]Ian James Wood: Ah! Yes, in that case Stealth will let them use Cautious Movement without triggering AROs.
    DISCOBALL
    Q: discoballer can be used as an ARO in ftf ?
    19/12/24 [20:07]Ian James Wood: It can't create a FtF Roll.
    Q: well same as smoke then
    19/12/24 [20:13]Ian James Wood: No. Template weapons have specific exclusions allowing you to place the template on the table at declaration. Anything else, like a Pitcher, Mine Dispenser, Disco Baller etc. get placed in the Effects step like normal.
    EXAMPLE OF IMPACT TEMPLATE WEAPON
    Q: guys all the text there has no bearing on the interaction that creates confusion, you should also read
    19/12/24 [13:26]Ian James Wood: Heletilla is asking for an example where the Fusiliers are in their Active Turn, and the Impact Template Weapon is being used in ARO.
    For example Fennec 2 activating, which results in Fennec 3 being hit without a chance to Dodge.
    And good old 'I'm standing too close to the Active Trooper'.
    20/12/24 [14:00]Ian James Wood: In this particular case, I'd argue that the example doesn't exist.
    The game effects of Impact Templates are different enough between the Active Turn and Reactive Turn that an example for Active Turn shooting doesn't help players understand the implications for Reactive Turn shooting.
    IMMUNITY
    Q: Would you mind weighing in on IMM applying to SD+x or +XB MODs? I assume it can't because SD and Burst are applied at declaration, which is before IMM meets its requirements. Whereas SR etc are applied at Saving throws so work. Right?
    20/12/24 [13:45]Ian James Wood: Exactly. And neither of those are affecting the Immunity Trooper's Saving Rolls or Attributes etc.
    SR-X + PS=Y
    20/12/24 [13:51]Ian James Wood: I assume that SR-X and PS=Y will be FAQed to either both work or both not work against Immunity (ARM/BTS/Enhanced) for consistency, but that's going to have to wait until next year.
    Q: PS=Y is part of the Effects of the Ammunition for Mono and K1
    20/12/24 [13:52]Ian James Wood: That's ARM=0. Not PS=4 etc.
    DICE
    Q: I dunno. I found it pretty obvious that saying that each dice is compared separately also means that the Main Target's dice will not in any way aid the secondary target
    20/12/24 [14:04]Ian James Wood: It's possible I misunderstood part of the conversation, but I thought what was considered to be missing was bystanders getting hit without a chance to make any kind of FtF Roll.
    SILENT WEAPON
    Q: Can someone please help me understand silent weapons? It says it imposes a penalty to dodge AROs when the target doesn't have line of sight, but ARO rules only say you get a dodge out of LoG when targeted by a template weapon or comma attack. When you back shoot someone, they don't have a reaction, right? Then what's the point of silent weapons?
    20/12/24 [19:15]Ian James Wood: Or when in Zone of Control.
    Q: Actually Silent does do anything outside of ZoC. So if the target has sixth sense, you might as well get within ZoC to shoot if you can, so you can apply the negatives
    [19:50]Ian James Wood: It's not going to help against Sixth Sense, though.
    FTF ROLL
    Q: They really should fix it. It was like this for the whole of N4 at least. Maybe before that as well.
    Some websites explain the rules RAW which as above clearly says equals don't cancel. Bit confusing.
    Examole :
    Active rolls: 10, 8, 6
    Reactive rolls: 8
    With equals cancels: The 8's cancel and active only gets 1 hit through.
    With successes only cancel lower results: The reactive 8 only cancels the 6. So active gets 2 hits through.
    21/12/24 10:56]Ian James Wood: Could you give me a specific example of a FtF Roll where this changes the result?
    Aaaah! I see where the mixup is.
    The green box is talking about a tied FtF Roll. The text for cancelling lower successes is talking about individual successes within the FtF Roll. Your example isn't a tied FtF Roll, that would have been 10, 8, 6 vs 10. Or 8, 8, 6 vs 8.
    I can put it forward for an FAQ or to be tweaked in errata to make it clearer, but it's likely to be given a low priority given how infrequently it gets asked about.
    If the FtF Roll is tied (the highest rolls are equal), the whole roll gets cancelled.
  3. Jim the third
    Jim the third Well-Known Member
    Not sure if it's the lack of context or I'm still in my post-xmas food coma but I'm struggling to understand most of these. E.g. the last one, is the question actually answered? Should the active roller get 1 or 2 hits through with 10, 8, 6 vs 8?
    WarHound and xagroth like this.
  4. Papa Bey
    So another platform to keep up with. Yey.
    That's the discord problem.
    #5 Wizzy, Jan 2, 2025
  6. wes-o-matic
    wes-o-matic Meme List Addict
    Having been on both, Discord is better for almost everything except rules questions, and it’s only worse for those because you can’t find the content via search engines like Google. (There’s a persistent thread forum feature in Discord and it works just fine, but the big server doesn’t use it for rules questions for whatever reason.)
    Henshini likes this.
    Servant
    23:30]BTSherman "I won't read": Cuz it's the tag doing it through the peripheral. Might be wrong there since these things have their own profile
    [31/12/2024 23:44]Ian James Wood: That's Servants. In this case it's the Ancillary that's the one performing the Skill, and rolling on its Willpower.
    Exemple : Interraction Attaque BS x Mine
    [02/01/2025 18:55]Ian James Wood: In this particular case, MSV3 isn't adding anything new, as it's almost identical to trying to attack the camouflaged Mine via Intuitive Attack, or shooting another nearby target with a template weapon.
  8. xagroth
    So many problems could be solved by making all mines be prone S2 markers... sure, you couldn't bait the opponent to think it's a sniper in camo state ready to ARO, but that only works with really new players (not to mention the troops that have unique Mimetism values with a camo state, like the Proxy 2 or the Agema HRL for example).
  9. psychoticstorm
    That is true.
  10. iKon
    iKon Not Very Well-Known Member
    Just make Mines S2.
    TAG & Fireteam
    Q: How do TAGs work in fireteams if they pop out their peripheral. Are they even allowed to declare that?
    [04/01/25 13:02]Ian James Wood: Last sentence of Peripheral (Ancillary):
    If the Controller deploys their Peripheral (Ancillary) ... the Controller automatically stops being part of the Fireteam.
    Autorepair
    Q: Autorepair cancels the Unconscious state.
    [07/01/25 13:36]Ian James Wood: It may well get an FAQ or errata to say that at some point. Currently it removes a Wound, and then you check to see if removing a Wound cancels Unconscious State.
    Q: I disagree that the rule as written conveys the message that Unconscious, if still present after removing one wound token, is NOT removed.
    [16:18]Ian James Wood: Thanks. Is this more about AutorepairS, or Unconscious Cancellation bullets?
    The Unconscious cancellation bullet requires you to remove a Wound Token and have fewer Wound Tokens than your VITA/STR Attribute.
    Q: Autorepair's "if applicable" sentence
    [16:20]Ian James Wood: Right, but that has to be present as a reminder to the player to check if Unconscious State has been cancelled.
    Q: Huh. Spanish doesn't have that line at all
    [16:31]Ian James Wood: Yeah. The Spanish version of the text doesn't work, because cancelling Unconscious State doesn't remove the Wound Tokens, so the Trooper would immediately enter Unconscious State again.
    cc with no LOS
    Q: Hi, wasnt there an announced of N5 rules that hitting in cc with no LOS from the victim, the attack automatically crits? In addition, CC does not require LoS, so the victim can always ARO with CC, I really dont know why I had this in my head....
    [14/04/2025 18:49]Ian James Wood: You're probably thinking of the -3 MOD for Dodging if the Active Trooper is in ZoC and outside LoF. Now that Silhoeutte contact no longer grants 360° LoF.
    Restrictions are for the Place Deployable skill regarding the placement of game elements
    Q: Cool, thank you. Can you clarify what the restrictions are for the Place Deployable skill regarding the placement of game elements?
    E.g.: Can you place Deployable Cover in silhouette contact with an allied Trooper? Would this grant it cover, if applicable?
    Can you place a Drop Bear or Armed Turret in silhouette contact with Deployable Cover? What about in silhouette contact with a neutral or enemy Trooper, Objectives, and Tokens. Would this put them into an engaged state, if applicable?
    [20/01/2025 22:07]Ian James Wood: The restrictions for Place Deployable are in Place Deployable, mostly in Effects bullets 2-3. Drop Bears etc. aren't going to cause an Enemy Trooper to be in Engaged State as they aren't Troopers and therefore won't trigger the Activation clause for Engaged State.
    Jump and Hacking
    Q: If the active hacker activates while an enemy hacker is within ZoC of the active players repeater, yes they would get an ARO and could dodge, although then they'd eat normal rolls on any incoming hacking attack
    => Vaulting is free movement, but beware of extra AROs without having Partial Cover because of it, images confirm vaulting works on the flip back to horizontal for Climb
    [22/01/2025 18:33]Ian James Wood: Vaulting is part of the General Movement Rules :
    Quote rule :
    Jumping movement must follow the >General Movement rules< as well as the Moving and Measuring rules.
    Some Troopers have the Jump Skill listed in their Unit Profile with a distance shown in round brackets. These Troopers can Jump the listed distance, instead of 6 inches.
    Declaring Jump cancels automatically Prone State.
    I'm hoping it will be explicitly spelled out in an FAQ, as it's very easily missed. As it's not shown in any of the Jump diagrams.
    Measure distances
    Q: By the by, while you're here, have any input on whether we measure distances between unit independent of scenery or the closest scenery-free LOF?
    [22/01/2025 13:52]Ian James Wood: It's unchanged from N4. You measure in a straight line from the closest part to the closest part.
    The closest scenery-free LoF might not be measuring from the closest part to the closest part.
    And yes, the example diagram (N4 and N5) is misleading.
    Speedball
    Q: I am reading Speedball right now. You are wrong. It literally says "they must automatically remove a wound"
    And the example doesn't contradict the rules. Don't confuse examples that add stuff that's not in the rules
    . That's shitty rules writing. But it is not a contradiction. Maybe. But the example doesn't touch that
    The speedball rule says "if applicable, this will cancel their Unconscious state" which is weird phrasing
    [12:29]Ian James Wood: We've been through that one. It's required, because the Trooper might not be in Unconscious State, and even if they are, removing a single Wound might not be enough to cancel Unconscious State. See also the equivalent phrasing for Regeneration.
  15. Willen
    Willen Well-Known Member
    Perhaps I missed this, and dont really want to go to another platform for rules clarification, but has it been clarified if the Thunderbolt (+1B) TR bots intend to apply that burst bonus in reactive? RAW it doesnt but a lot of people seem to take it as a yes RAI.
    Also the topic of order count / army orders towards use of a CT to strip to orders (restriction of maximum 10) has it been clarified if it means order on the order pool count, or total army orders? Thanks!
    Everything he said on discord about the rules is indexed here, he also seems to talk on the facebook group but I don't have a facebook account and access it.
  17. Mahtamori
    The last one about Speedball isn't a question as such, it's just Ian catching the tail end of half an hour of... discussions. It isn't providing anything that isn't more clearly read here: https://forum.corvusbelli.com/threads/n5-q-a-discord-for-rules-by-ijw.43302/#post-480946
    Wizzy likes this.
    dodge from Look out! be used as a f2f roll against bs attack
    [04/2025 12:01]Delusionist: Can dodge from Look out! be used as a f2f roll against bs attack?
    [04/2025 12:03]Ian James Wood: Yes.
    Prone is prone
    [04/2025 19:22]Odd Luck: I assume you're allowed to know the size of the marker, not the model.
    04/2025 19:11]Four: Camo specifies what you cannot ask about the trooper
    [04/2025 19:11]Four: Their real silouette is not one of those options
    [04/2025 19:20]Four: As far as I'm aware the camo rules are pretty specific about what can be asked
    04/2025 19:24]Ian James Wood: You can ask for the Silhouette value. If the Trooper is Prone, the value is X.
    04/2025 19:33]Ian James Wood: It doesn't matter. The Camo marker has the same Silhouette value as the Trooper. The Silhouette value of a Prone Trooper is X.
    For the avoidance of doubt:
    Camo marker A is a Prone Caliban.
    Camo marker B is a Prone N4-N5.0 Seed Soldier.
    The Silhouette value of both these Troopers, and therefore of their Camo markers, is X.
    Asking for the Silhouette value of the Camo markers cannot tell you that one of them is a Seed Soldier.
    04/2025 19:03]Ian James Wood: If the Camo marker is Prone, it is SX, regardless of the Trooper's actual Unit Profile.
    Asking what the Silhouette of a Prone Camo marker is cannot in any way reveal that it is a Seed Soldier.*
    *Excluding obvious exclusions like a Prone Camo Sphinx due to the base size.
    EDIT obviously that should be an Anathematic in generic CA, not a Sphinx!
    Martial Art & CC Attack (+1SD)
    [03/05/2025 04:12]Inane.Imp: ^ it does. CC Attack (+1SD) wouldn't but MA isnt a +1SD Mod in round brackets next to the skill so isnt affected by the limitation on when this Mod applies (pg 23). Martial Arts effectively is a distinct implementation of SD that does not include the Long Skill restriction.
    Does anything have both Berzerk and CC Attack (+1SD)?
    03/05/2025 09:32]Ian James Wood: It's not a separate implantation of +1SD, but that doesn't matter because Berserk explicitly allows +1SD even though it's a Long Skill.
    [03/05/2025 10:16]Inane.Imp: It might not be intentended to be, but it does work separately: it lacks the restriction of the regular one and doesn't refer to (+1SD) just to +1SD.
    03/05/2025 10:21]Ian James Wood: And that take on it is exactly why I wanted the entire block of text removed from Martial Arts, and the 'same' block of text removed from the Fireteam Bonuses.
    It just leads to copy-paste errors if one bit gets updated and the others don't, and makes players think that they are different rules.
    03/05/2025 10:27]Ian James Wood: Or add it (the brackets) to the MA chart
    tinbot
    [05/05/2025 - 20:35]Infradyne: 0.5 SWC Lıeutenant: technically RAW as I see it the tinbot token doesn't have to be placed with the owner. It just says it gets removed with the owner when they die
    [05/05/2025 - 20:37]Ian James Wood: 'Prior Deployment
    You must place this weapon or piece of Equipment on the game table during the Deployment Phase.'
    #19 Wizzy, May 3, 2025
  20. Wizzy
    An discussion for :
    Wounds & Transmutation
    [13:53]Inane.Imp: But yeah: making Escape System work better and pricing it lower and you solve the profile issues. Literally:
    Wounds dont transfer, all states are cleared.
    Both Operators BS13, MOV 6 2.
    50pt Annie
    56pt Iggy
    Iggy in vanilla instead of Gator.
    I'd run a vanilla Iggy list next week if that happened.
    [14:04]Ian James Wood: If Wounds don't transfer, you'd need to inflict six Wounds to take it Unconscious.
    I assume you mean that you can't inflict more than X Wounds to the TAG profile? Which has its own issues.
    [14:06]Genghis Cohen[GH] : Yeah I understand the desire to have it be good by stopping 'carry-over' of Wounds, but that is completely opposed to how other similar rules are set up to work.
    14:07]Ian James Wood: Yeah, the whole point of the Transmutation changes are that you have a single STR/VITA total, and compare received Wounds to it.
    22:04]Pandamonium: No you wouldn't, it doesnt have Remote Presence, only 4 wounds would be required.
    22:30]Ian James Wood: If Wounds received by the TAG profile don't transfer to the Operator profile, then:
    TAG receives 2 Wounds.
    Transmutation kicks in and you change to the Operator profile, removing the 2 Wounds that have been suffered.
    The Operator has VITA 4.
    So a further 4 Wounds would need to be received to take it Unconscious.
    For a total of 6 Wounds received. But I'm 90% sure that's not what Inane.imp meant anyway.
