Movement Worm, Sensor and All at the Same time.
Discussion in '[Archived]: N4 Rules' started by AntipodeanBolt, Jul 7, 2024.
  1. AntipodeanBolt
    AntipodeanBolt Bureau of Colonial Affairs Spokesperson
    Hello.
    Can someone please walk through the process of how the “Movement Worm” interacts with Sensor?
    Do you activate it at a particular point or is it active for the entirety of your move enabling you to sweep with a Sensor Worm for example a 4” movement range and a 8” ZoC sweep.
  2. Errhile
    Say what?
    Someone decided they can use Sensor - an Attack - for the entire duration of their Movement?
    I thought any Attack took place at a specific point of your Movement. The exact point was for the attacker's to choose, but the entire attack had to be perfromed from that single point.
  3. psychoticstorm
    I am not sure what the movement worm is, but if it is what @Errhile said then as he said, it cannot be done.
  4. AntipodeanBolt
    Movement Worm is the simplest explanation to visual a unit's movement. As the unit moves during an order it creates a worm like shape.
  5. psychoticstorm
    Ah I see that makes sense.
  6. Methuselah
    Methuselah Well-Known Member
    Hey! Can you please point me to this rule? I can find references for position in BS Attack and restrictions on declarations for attacks, but I cant find something for performing under the general 'Attack' label. Thanks!
    In general, I think most everyone plays this rule as occurring in a single position.
  7. iKon
    iKon Not Very Well-Known Member
    ZOC is measured from ANY point along the path and not EVERY point along the path.
    Simply put, you can not be everywhere all at once.
      File size:
      25.2 KB
      3
  8. Infinity_Gamer
    Laughs in Holoprojector
    Arkhos94, Delta57Dash and Methuselah like this.
  9. Methuselah
    But you do occupy every space along your movement path for that order. Also ANY can mean EVERY. You could measure ZOC from every point along the path and be within the rules and guidelines.
    Amusedbymuse and Delta57Dash like this.
