I've playng MO for alot, and i would kile to explore PanO other style of ifghting (maybe full focussed on ranged combat). Wich sectorial i should point for this, or Vanilla is better?
Hello, probably, whatever you choose it will be allright, because MO has a really particular style inside "Pano". It depends of what do you want to try. Best general shooters... but practically no "half table game", or really expensive. Winterforce: you could have here some CC, probably even better options that in MO for CC in exclusive, but it is more a sectorial of shooting. It could be said that Winterforce is the best shooter Pano has right now, if we are talking in medium CD values + mimetism (-3) or (-6) + visors, but all should work together in fireteams. Not too many defensive options. or Neoterra... You have here the best individual shooters from Pano, so you don't need to work with fireteams if you don wish to. Of course you have excellent fireteam options. Better defensive choices than Winterforce: "auxilias for the win". ARO active masterpiece... then go to Varuna as fast as you can. You have here the best active ARO pieces whole Pano can put into the table, but the active killer pieces are quite limitated in comparaison to the defensives ones and with the others sectorials, so you have to move carefuly in your active turn and choose the firefight wisely. Many CD 13 options. Jack of all trades... and probably the most far away from "Pano style", you should try ASA. Almost all the pieces are "fragile", but you can put in the table really great combinations from active killer troups with defensives ones. You have Dart too, like in MO, but how she works in Acontecimento is too different. I wil go first for some of the sectorials, but if you want to try a combination of "double tag list" and this combo don't exist in any sectorial, go for it with vainilla. Same for some mix of profiles, like Joan D'Arc with a lot of irregular guys, this works much better in vainilla than it could do it in MO. In vainilla you have acces to all the "good gunfighters" you can have in NCA or Winterfoce, and too the some of the defensive ones from Varuna (Ilotas, ZuluCobra+jammer) and Acontecimento (regular minelayer) with the classic Crocmen to work in half table. Here you will miss a lot the trinitarian if you used them in MO.
