Today I have sleeved the expansion and thought myself, the cards are not fitting the sleeves. The sleeves are to big. For the CORE game I used the 43mm x 65mm sleeves as the 41mm x 63mm sleeves were 1 mm less in width. But for the expansions are these to big, as the cards from expansions are 2,5 mm less in width. Anyone have it same? Picture for reference, at the bottom card from CORE game and on top of it from expansion.
I'll check mine when I got home, but my loot cards from the expansion were a darker shade of colour on the back, so it's rather obvious when they come up in the loot deck.
I strongly recommend to check mini cards from Revenant expansion, as mine weapon cards were really offset. So they are heavy blurred.
Also expansion cards seem to have lost in paper quality, I keep rubbing paper off from edges while putting cards in protectors. UPD. One miscut card so far
Mines are also smaller but I just rechecked them and books and there are no offset or blurred stuff for me. Maybe the paper is slightly lower quality but once they are in the sleeves it does matter.
Which sleeves are people using? I stupidly didn't get the sleeves with the KS. Are they Mini-USA or Mini-Euro for the mini cards? Same question for the larger ones, they seem to be too small height wise for tarot sized.
There's space on the sides of the cards if you're using the sleeves that CB offered, but the sleeves are thin enough that's still snug. (If you can pinch a sleeve by one of its corners and fling the card around, you can get the card to slide out of the sleeve, but you sort of have to be trying something like that to get them to slide out.)
