Marksmanship optional vs. Albedo?
Discussion in 'Rules' started by theomc, Feb 26, 2025.
  1. theomc
    theomc Well-Known Member
    I've seen people go both ways on this, Marksmanship is listed as an Optional skill, but Albedo says "Any enemy with ... the Marksmanship skill" (not "that USES the Marksmanship skill")
    So if a model with Marksmanship shoots a model with Albedo, can they choose to not use Marksmanship and not suffer the penalty (and also not get the bonus from Marksmanship)?
  2. Iskandar
    Iskandar Well-Known Member
    The current rules don't care if you are using the skill just that you have it so until it's FAQ'd otherwise that's how it works
  3. theomc
    That's what I thought, my only question then is, why is the Marksmanship skill Optional?
  4. Iskandar
    It's been like that since N3 when nested skills existed and shock was part of it
  5. xagroth
    I will throw some kerosene to this fire...
    RAW this happens with stuff that has the Reflective property, which is irrelevant for Eclipse (since you can't draw LoF through it). BUUUUT! White noise!
    Could it be that you can deploy White Noise to negate the use of Marksmanship to the enemy? (They could draw LoF anyways unless they have MSV)...
