Marking LOF on bases
Discussion in 'Access Guide to the Human Sphere' started by Ruaridh, Feb 9, 2021.
  1. Ruaridh
    Ruaridh Well-Known Member
    Hey guys does anyone have something like this but for infinity base sizes or have a link to where I can find one? So I can accurately mark LOF please? A printable pdf would be great for an a4 sheet
    Thank you in advance :)
    Sent from my SM-G973F using Tapatalk
  2. herod1204
    herod1204 Knight of Santiago
  3. Ruaridh
    Thank you so much :)
  4. chromedog
    Did nobody else learn how to bisect a circle at school in geometry?
    A ruler and a set square were all you needed to find the diameter line of any circle. Mark a chord (line linking two points on the circumference). Mark another chord at RIGHT angles to this one. Join the outermost points. That line passes through the centre.
    That said, there are a bunch of arc marking aids out there on the internets.
    Ruaridh, Mob of Blondes and Hecaton like this.
  5. Mob of Blondes
    IIRC here it was plain ruler and compass (any chord, then bisect it, another chord, bisect and check where those new lines cross). OTOH, I think I remember the "any view, in circunference, of diametre is always =90 deg" property from somewhere else (and inside >90, and outside <90), which is what you describe.
    chromedog and Ruaridh like this.
  6. Nuada Airgetlam
    @Mob of Blondes @chromedog
    You guys just are the definition of overkill :D
    I place the 25mm bases on checkered paper, one takes 5x5 squares, it's obvious where the middle is (middle of middle square).
    Boom.
    Ruaridh likes this.
  7. Mogra
    Mogra Well-Known Member
  8. Ruaridh
    I mean the first guy got me pretty sorted with a link to print off exactly whatbinwas after but thank you :)
  9. Errhile
    Really nifty, indeed.
    But requires one to have access to a 3d printer. And the skill to operate one.
    So, me having neither, I'll keep to my dinosaur-analog-age ways ;)
    #9 Errhile, Mar 2, 2021
  10. toadchild
    Ruaridh likes this.
