    Dismiss Notice
Losing 6th sence Fireteam bonuses while declaring delayed ARO
Discussion in 'Rules' started by JoKeR, Jul 3, 2020.
  1. JoKeR
    JoKeR HAWZA Instructor
    lets suppose Player B is a reactive player with a full Enomotarchos (4 members) fireteam.
    Player A is active player & he activates his trooper in ZoC of all members of mentioned Fireteam.
    Player B decide delay ARO using 6th sencess given by a fireteam bonus.
    Player A declare second short skill of his trooper.
    Now player B want to declare different ARO's with his fireteam members. he want three of them dodge, while last of them shoot.
    it possible as a fireteam integrity says to us
    http://wiki.infinitythegame.com/en/Fireteam_Integrity
    but the same Fireteam integrity states that now player B must re-calculate his fireteam bonuses.
    So that happen in resolve?
    does fireteam members can accomplish their different ARO's or they lose 6th sences so lose ARO's with the ability to delay it during the order?
    @ijw @HellLois
    #1 JoKeR, Jul 3, 2020
  2. toadchild
    If you split your ARO, none of the members will have sixth sense, so you would not be able to delay. You must either declare the same ARO for everyone of forfeit entirely.
    JoKeR likes this.
  3. JoKeR
    TY @toadchild. honestly i have a same thoughts.
    so in most cases with a four or five members fireteams after delay ARO with them you will know your opponent second skill but used to declare same ARO's - else you just lose fireteam member without any profit.
    only one case i found when you still can do different ARO - any tartary full members core fireteam with a veteran Kazak in it. after delay veteran declare separate ARO. he still have 6th sence to make it legit, while core left with four members - also still legit to declare their own ARO.
    #Ariadna_strong!
    but i still want to see @ijw & especialy @HellLois thoughts
  4. QueensGambit
    QueensGambit SecUnit
    Counterpoint:
    Sixth sense allows you to delay the declaration of your ARO until later in the order sequence. It only affects the timing of the order sequence.
    The rules say that "a Skill declaration is not valid if the Requirements for their execution are not met" in which case the unit is deemed to have declared Idle instead. But "was declared at the correct point in the order sequence" isn't a Requirement for execution of a Skill (this is easily checked since each Skill has a box listing its Requirements).
    "Delay" itself isn't a Skill declaration, doesn't have Requirements, and can't fail at the Resolution stage and become an Idle.
    Losing sixth sense at the Resolution stage can't retroactively change the order sequence. Because of the All At Once principle, in the Resolution phase you don't consider _when_ each Skill was declared. You just look at all the declared Skills, determine which ones have all their Requirements met, and resolve all those Skills simultaneously.
    I'm not sure that's the correct analysis, but I don't think it's clearly the reverse, either.
    JoKeR likes this.
  5. Mahtamori
    I don't think this has ever been officially answered, and it has been asked several times over the years of N3, but keep in mind that this is not too dissimilar from when a unit declares a delayed ARO using Sixth Sense only to find out the enemy unit was/is out of range during measurement.
    I've personally always gone out of my way to never let this become an issue during games, simply because I've never been able to answer nor arbitrate it with confidence, though I'm partial to the interpretation that the delay is invalid if the unit loses Sixth Sense and thus causes all skill declarations to fail (note; this is different from "not happen" as units will still get kicked from the team for declaring divergent AROs).
    Basically, if you're looking for an answer from Helllois or IJW you might never get one before N3 is history, so maybe make a house rule?
    JoKeR likes this.
  6. JoKeR
    @QueensGambit thanks for your point, by the way
    please explain how you fortheit this part of the rules:
    "The Reactive Player must declare AROs for all eligible troopers immediately after the Active Player declares his Entire Order or the first Short Skill of his Order (see: Order Expenditure Sequence). Troopers that fail to do so lose their ARO against that Order. "
    http://wiki.infinitythegame.com/en/ARO:_Automatic_Reaction_Order
    cause troopers re-calculate their fireteam bonuses & have NO 6th sences for the whole order, or in other words, have No ability to delay ARO at all.
    @Mahtamori , tnx too. i know the situations with this question. also i have my own "homerule". but always need to check out own thoughts with comunity.
    i work alot with @ijw & @HellLois & belive they would help if they can. as you can see - i ask their thoughts about this question, not the "rulling". Working with Lois show us, that even he cant solve some rule questions with his own will. it always hard work, N3 FAQ's prove it. If we can make some good points here - i'll be happy. if we can make entry for N3 FAQ - excelent. if by our asking we close this gap in N4 - it would be perfect!
  7. QueensGambit
    So, we know that that rule doesn't apply to a unit with Sixth Sense when the active unit is within its ZoC, because Sixth Sense allows the unit to delay the declaration of its ARO.
    The question is, does the rule apply retroactively when the unit had Sixth Sense at the time it delayed its ARO declaration, but lost Sixth Sense at the time that it declared its ARO. In this scenario, the declared ARO itself is still valid, but the time at which it was declared was, arguably, retroactively too late. I agree with @Mahtamori that the rules don't appear to answer that question.
    If we do apply the rule you quoted retroactively, we get this:
    1. Active unit declares its first Skill.
    2. Fireteam units all delay their ARO declarations.
    3. Active unit declares its second Skill.
    4. Fireteam units declare divergent AROs, causing them to lose Sixth Sense.
    5. Applying the rule quoted, the units now all _lose their ARO_. Note this is different from the rule I quoted where a Skill's Requirements aren't met. When the Requirements aren't met, the ARO is converted to an Idle. But where a unit fails to declare an ARO at its first opportunity, it loses the ARO completely (does not Idle).
    6. So now, retroactively, none of the fireteam units declared any ARO.
    7. Which means that they didn't declare divergent AROs.
    8. Which means that they didn't lose Sixth Sense....
    And then the fabric of the universe collapses in a time loop paradox, and it's ALL YOUR FAULT.
    Ariwch and JoKeR like this.
  8. toadchild
    It's not a time loop paradox, because not declaring an ARO is legal, regardless of whether or not you have sixth sense. Step 8 would be that your fireteam is still intact but declared no ARO, and gameplay continues with the next order.
  9. QueensGambit
    Mmm, I'm not sure I buy that. Yes, not declaring an ARO is legal, which is why it's possible to say that retroactively, they didn't declare any ARO (having failed to do so at step 2 which is the point when, retroactively, they had to choose whether to declare or not).
    But once we allow that retroactive change, so they didn't declare any ARO, it follows that they also didn't lose their fireteam bonuses. Which means they still had Sixth Sense throughout the order. Which means we can't disallow them from delaying their ARO until step 4.
    There's no basis on which we can take away their fireteam bonus, except that they declared divergent AROs. But unless they have their fireteam bonus, they didn't declare divergent AROs (or any AROs at all).
    I don't know the right answer, probably @Mahtamori is right that it just takes a house rule one way or the other. But I think it's a genuine time loop if we try to apply the rule retroactively.
  10. ijw
    I've not seen anything new that changes my opinion from the previous discussion - they will lose their AROs if there aren't enough members left in the Fireteam.
    QueensGambit, JoKeR and Lesh' like this.
  11. JoKeR
    No way, Doctor @QueensGambit , its all YOURS! :A:
    cause your make this expiriment WRONG!
    as you know - even the fact of JUST DECLARING something could change everything in Infinity. For example camo declaring hacking & find out his target out of hacking area still lose camo state cause fact of just declare skill, even not perform it.
    So between point 5 & 6 in your scientific work still comes
    5.5 they declare different ARO, re-calculate fireteam, & some of them LEAVE faireteam due this fact.
    leave without come back even despite they not perform their ARO.
    so no "saved" six sencess, no infinity loop.
    Check-mate, mate. I save the Universe from your "infinite loop paradox", no need to thanks :stuck_out_tongue_closed_eyes:
  12. JoKeR
    tnx @ijw for come & re-post your thoughts about this problem. :+1:
  13. QueensGambit
    @ijw has resolved the original question, so we can move on to something else:
    Is that correct? Do you have a source? I've always wondered how this would work. Especially if the camo declared it as an ARO, I always kind of thought that if it turned out to be out of range, camo would not lose the marker state. Since it would never have had an ARO in the first place (assuming no LoF to the active unit).
  14. JoKeR
  15. QueensGambit
    Well, but that doesn't answer the question of what happens when the trooper attempts to declare a skill, but it turns out they were not in fact allowed to declare it because they had no ARO.
    What if I want to uncamo a trooper? Suppose we're playing Acquisition. I have first turn. On my turn 3, I move a camo unit into contact with the tech coffin but it's still in marker state. I want to keep it safely in camo for as long as possible, but reveal it at the end of your turn so that I control the tech coffin. So I wait until your last order. You activate someone on the other side of the board. I declare that my camo unit will use a ZoC ARO to Change Facing. You point out that the active trooper is obviously not inside my ZoC. I say "no problem, let's measure it. Yup, turns out you're right, that's way outside my ZoC. Oh well, my trooper declared an ARO so he's revealed anyway."
  16. toadchild
    I guess my point was more that entering and remaining in the loop requires the active choice of the controlling player. You can choose to exit the loop and remain in a legal game state. This isn't some sort of Marauding Raptor + Polyraptor situation.
  17. QueensGambit
    Fair enough, we may just have been using "time loop" differently. Probably my fault because I wanted an excuse to say "time loop." Really it's more of a paradox along the lines of "this statement is false." No time travel.
    Anyway it doesn't matter anymore since @ijw has ruled on it.
    toadchild likes this.
