Looting and Sabotaging, using CC multiple model bonus on the AC2?
Discussion in '[Archived]: N3 Rules' started by Anonymous, Jul 11, 2018.
  1. Anonymous
    Anonymous Guest
    The question is fairly simple, The AC2 is not considered to be an enemy trooper, so I am asking if it would be possible to get Burst and PH bonus when multiple friendly models are attacking the Antenna.
  2. Arkhos94
    Yes regarding fireteam :
    In Close Combat, whether in the Active or Reactive Turn, when several members are engaged in the same CC, only the Team Leader trooper will perform the CC Roll, gaining a MOD of +1 to his B and +1 to the PH Attribute for Damage for each Fireteam member Engaged with the adversary.
    And yes regarding coordinated order :
    In Close Combat, only the Spearhead trooper will perform the CC Roll, getting a MOD of +1 to his B and +1 to the PH Attribute for Damage for each friendly trooper participating in the Coordinated Order engaged with the adversary
    In both case you need to be in the same CC/be engaged with the same adversary (not trooper) so it works
  3. inane.imp
    No for Fireteam. Being B2B with the objective doesn't mean that you're in the Engaged state (which Fireteam explicitly refers to)
    NFI with co-ord and G-Sync but I think it's Yes because they're all engaged in CC.
    Oh yeah, it's a doozy.
  4. ijw
    Given that all the rules involved use lower-case 'engaged' at some point, it's going to be the same for all of them.
  5. inane.imp
    That's not actually necessarily true.
    The Fireteam rules can be read as follows:
    "When multiple troopers are engaged in CC only those in the Engaged state provide bonuses."
    But it IS far cleaner.
  6. ijw
    Please re-read what I posted. :-(
  7. inane.imp
    I have.
    Feel free to elaborate.
  8. ijw
    Are you contesting that lower-case 'engaged' isn't used in the Fireteam rules?
  9. inane.imp
    No.
    Edit for clarity: I'm saying that it's not necessarily true the outcome will be the same despite the fact they share a phrase.
    Are you saying that you don't need to be in the Engaged state to provide bonuses in CC as a member of a Fireteam?
    Or are you saying that 'engaged in CC' and 'Engaged' is functionally the same (without actually saying that)?
    Because I read 'engaged in CC' and 'Engaged' as dissimilar requirements (Fireteams have both,. Gsync and co-ord only have the former).
  10. ijw
    Ah, thank you, I'd missed that distinction in your post!
    Yes. All definitions of close combat in Infinity tie back into the Engaged state, as they all talk about being in base contact with an enemy, i.e. being Engaged.
  11. inane.imp
    So you can't CC attack the objective in L&S at all?
    For clarity: Engaged requires you to be in B2B with an enemy Trooper.
    CC just requires you to be in B2B with a valid target.
  12. ijw
    Basically, for CC Attacks to work against scenery at all, you have to assume that it all works, or none of it works. :-(
  13. inane.imp
    No. Because CC Attack doesn't have the Engaged state as a requirement, only B2B.
    Which is why I think 'engaged in CC' and 'Engaged' are different.
    There is no mention of Engaged as part of CC Attack.
    "Common Skill employed to attack in melee combat against an opponent in base to base contact.
    CC ATTACKSHORT SKILL/AROAttackREQUIREMENTS
    The user must be in base to base contact with an enemy.
    EFFECTS
    The user employs his CC Attribute to fight in Close Combat (CC).
    By declaring a CC Attack, troopers automatically draw their CC Weapons. If they have more than one CC Weapon in their profile, they can choose which ones to use. When declaring a CC Attack players can only use those weapons with the CC Trait.
    If the attacker has more than one target and a Burstvalue higher than 1, he must distribute his attacks as part of the CC Attack declaration"
  14. ijw
    BtB contact with an enemy. Which is what activates Engaged state.
    Please note that I'm not claiming that this is all clear in the rules, I strongly dislike the interactions of CC and scenery structures/equipment being so undefined.
  15. inane.imp
    Enemy Trooper for Engaged. Not merely an enemy. Objectives are not Troopers ergo you do not become Engaged with them.
    Considering the objectives as 'enemy's' is necessary for basically all ITS (and should probably be explicit).
  16. ijw
  17. inane.imp
    #17 inane.imp, Jul 11, 2018
  18. Ginrei
    Ginrei Well-Known Member
    Declaring a CC Attack at all requires being in base to base with an enemy.
    So you can't declare a CC Attack against anything other than what Infinity defines as an enemy trooper and explicit exceptions. Break away.
  19. inane.imp
    You can only BS Attack enemies as well. It gets fun :)
    Ginrei likes this.
  20. macfergusson
    Basically you just have to assume that an AC2 acts like an (immobilized) enemy trooper for CC attack purposes, but only because that was made as an exception for that specific scenario. There's not really another way to handle it.
    ijw likes this.
