Maybe this question has been askes before, but I couldn't find it in the forums. So please forgive me if it is a repost. How ever, I played a game with a friend of mine and I wanted to play with the mighty new Armata-2 Proyekt "Ratnik". The question is as follows: The normal profile had Lo-Tech + Dogged and the Battle Ravaged profile has Dogged. Does the Ratnik goes A: Battle Ravaged and then Dogged. B: Dogged in normal profile, Battle Ravaged and then dogged again? I think it is option A, but I find it silly that both profiles have Dogged. Thanks in advance!
The dogged state can be triggered when the trooper enters the Unconscious state. When it suffers a wound, the unit goes into battle ravaged, not unconscious, therefore it cannot go dogged at that point
Dogged only takes effect when a trooper falls Unconscious, so it can only happen after Battle Ravaged.
So it's clear that you can use Dogged after losing 2 wounds in one order, if it wasn't on both someone would argue you can't use Dogged if you started the order at full health as the profile change doesn't happen until the end of the order.
