Lieutenant special order and Fireteam
Tema en '[Archived]: N4 Rules' iniciado por Dejmien, 29 Jun 2021.
Estado del tema:
  1. Dejmien
    Dejmien Member
    18 Dic 2017
    Hi,
    Can I activate Fireteam by spending Lieutenant Order on Lieutenant nominating him the Fireteam Leader?
    Either this is forbidden or it will cancel Fireteam?
  2. colbrook
    https://infinitythewiki.com/Fireteam_Integrity
    In the Active Turn and Reactive Turn, a Trooper stops being part of a Fireteam in the following cases:
    <snip>
    The Trooper is the Lieutenant and spends the Lieutenant Special Order.
    However, the NCO rule does allow you to spend the Lt. order while remaining part of a Fireteam, including the few NCO Lt.s like Norks and Moiras.
    A P4ela154 le gusta esto.
  3. P4ela154
    P4ela154 Active Member
    15 Sep 2020
    Will cancel. But if Leith has an NCO, he can use the order through this rule.
    A chromedog le gusta esto.
  4. colbrook
    I think it would only cancel the Fireteam if the Lt. was already the leader, otherwise they'll just leave the Fireteam.
    A Lawson y P4ela154 les gusta esto.
  5. Dejmien
    Dejmien Member
    18 Dic 2017
    Thank you.
Estado del tema:
