Khawarij MSV2 model - hollow head?
Discussion in 'Haqqislam' started by onko, Apr 3, 2019.
  1. onko
    onko New Member
    Khawa Head.jpg Got my Khawa box today.
    The MSV2 Khawarij seems to have a hole in his helmet on the right side, where face should be?
    Can anyone that had this box confirm if this is ok or not?
    It is quite difficult to tell if this was a miscast when it's not primed yet. On the box picture his face cannot be seen but the right part of the helmet looks a bit different.
    Thanks for your answers.
  2. Nuada Airgetlam
    Looks like a casting problem, talk to CB.
  3. 8vius
    8vius Member
    Mine also came like this, I just assumed it's how the model actually is.
  4. onko
    onko New Member
    It could be. Anyone else can confirm their MSV2 Khawa came like this?
  5. theGricks
    theGricks Well-Known Member
    OR its an Aleph infiltrator and there IS NO HEAD!
    oldGregg and Civilized Barbarian like this.
  6. moxtron
    moxtron Member
    As far as i can see it
    It seems to be designed like that, the visor combined with the mask are just very big i guess
  7. Barrogh
    Barrogh Well-Known Member
    Interesting, I've assembled mine and I don't remember seeing such irregularities. I will check this out when I'll get home, I guess.
  8. ldgif
    ldgif Well-Known Member
    I have noticed it look like the right side of the MSV2 face seems missing.
  9. Topshelf
    Topshelf New Member
    Mine was the same
  10. vorthain
    vorthain Veteran Novice
    Seems like the visor should be over his eyes anyway, but I guess he didn't need it for whatever close range pistol target he had. So a couple weird design decisions here.
  11. onko
    onko New Member
    Thank you guys. I will start building it then, will make the face dark as is in the studio pic.
  12. KedzioR_vo
    KedzioR_vo Well-Known Member
    Maybe you didn't look close/precise enough - mine has his left eye visible, and some kind of small visor on right.
    Will be FUN to paint :D
    PozdRawiam / Greetings
