Jammer into CC
Discussion in '[Archived]: N3 Rules' started by Rocker, May 7, 2019.
  1. Rocker
    Rocker Well-Known Member
    Does a jammer attack into CC apply the -6 mod as for BS attacks into CC?
  2. inane.imp
    Yes.
    Jammers ignore Vis Mods (ODD, TO, Camo, Mimmetism, Poor Vis, Low Vis etc). The -6 due to Engaged is not a visual mod it's caused by the Engaged state.
    Savnock and toadchild like this.
  3. eciu
    eciu Easter worshiper
    How do we know which mods are vis mods are which are not ?
    BLOODGOD and Hecaton like this.
  4. inane.imp
    We don't. Jammers are really badly written. But taking a conservative position on this is the easiest option (ie. unless it's clearly a vis mod then Jammers don't get to ignore it).
    The trait that seems to give Jammers the ability to ignore mods is 'No LOF'. Since there's nothing in either the Jammer or BS Attack into Close Combat rules that indicates LOF is a factor in why the MOD is applied ergo it LOF is not a factor and the MOD should be applied as normal.
    The strictest reading of the rules as written would apply ODD, TO, Camo and Mimmetism MODs to Jammers. There is no indication that these mods rely on LOF whereas this text is present in Low/Poor Vis Zones:
    "Any Skill, Special Skill or piece of Equipment that requires LoF and is declared from, into, or through a Low Visibility Zone suffers a -3 MODto the relevant Attribute in the required Roll."
    Since Jammers do not require LOF they certainly ignore those mods.
    However, previously we've been advised that Jammers ignore Mimmetism, TO, ODD and Camo MODs. This was on the old forums. This is the only reason people play it as ignoring those MODs.
    We have never been told that Jammers ignore the MOD for attacking an Engaged model.
    Furthermore, from a gameplay POV allowing Jammers to attack models engaged in CC with impunity is bad and should be resisted unless it is absolutely clear that it's intended.
  5. Marduck
    Marduck Well-Known Member
    Really ? Being in CC is imo obviously a visual modifier as it represent the difficulty to put a bullet on a target without hitting your friend.
    You don't get mod for hacking someone who is in CC. Why would you get some for a jammer ?
    EDIT : Jammer are probably too strong and should be nerf for sure (like isolated for only two player turn). But I don't like the rule being counter intuitive or inconsistent.
    theradrussian likes this.
  6. eciu
    This.
    I can see people making a (valid) point that Engaged state is "kinda of visual mod" and people arguing otherwise.
    So CB has to step in again and fix what they have broken.
    Unless this is example of this "coffee talk" and they are beyond our peasant problems ^^
  7. xagroth
    Comms Attack. But Technical Weapon. So it can go either way... /shrug
    And yeah, Jammers need to change so hackers can reply with something else than reset.
  8. Zewrath
    Zewrath Elitist Jerk
    I wouldn't say that the Jammer rules are broken. Broken implies that they worked some time before. Jammers were dead on arrival.
  9. eciu
    You are wrong.
    Jammer is what CB designed jammer to be.
    If you don't like it don't play it (dunno how you can "not play against it" ? ask opponent to be nice?)
    If you have problem go play other game.
    Don't post your critique as it is irrelevant.
    War is peace etc.
    AdmiralJCJF and theradrussian like this.
  10. Zewrath
    Solar, how did you get eciu's account?
    meikyoushisui and inane.imp like this.
  11. eciu
    I thought that my irony is obvious enough ;P
  12. inane.imp
    Because Hacking and Jamming are VERY different.
    With reference to the rules explain to me why we shouldn't apply the CC MOD? You won't be able to, ergo we do.
    Next someone be telling me that Jammers ignore Surprise Attack MODs because they're 'kinda a visual MOD' and it's more consistent.
    Ultimately, though, Jammers already avoid some MODs and are affected by others, this is nothing new.
    Hecaton and chromedog like this.
  13. Gunmage
    Gunmage General Contact Unit
    You also don't get fireteam bonuses when hacking someone.
    Zewrath, Hecaton and inane.imp like this.
  14. inane.imp
    It's not either way, nothing in Comms Attack removes the obligation from applying mods to the attack. Indeed Sat-Lock has this text to avoid doing it:
    This Roll applies no further MODs (for Range, Cover, CH,ODD...) or bonuses unless otherwise specified.
    Jammers do not.
    If anything the problem is that Jammers ignore ODD, Camo, Mimmetism and TO with no justification in the rules. Seriously why do they avoid those MODs? Justify it without saying 'because we were once told it was that way on a forum that is now dead'.
    Zewrath likes this.
  15. Zewrath
    inane.imp and eciu like this.
  16. xagroth
    Because all those are "optical" stuff that Comms Attacks, being faced with Reset, can ignore reasonably.
    Making the Jammer a Comms Equipment (so it could be Blackout'ed, for example) would bring the thing down a peg, also giving a little breathing room to the AHD (which are now kinda hidden because KHD).
  17. daszul
    daszul Well-Known Member
    You can even accidentally jam your own troop that is engaged there if you miss by 6 or less!
    Savnock, BLOODGOD and chromedog like this.
  18. Arkhos94
    seems like it should go to the unsolved question list, do we agree ?
    Savnock and Section9 like this.
  19. psychoticstorm
    I do.
    Savnock likes this.
  20. Brother Smoke
    Gotta be careful when attacking engaged units, it can be quite a...
    Jam...
    I'll see myself out
    barakiel, Savnock, eciu and 3 others like this.
