Hey all, a friend of mine is wanting to run a narrative event, and believes that there is a way to tie the event into ITS. Wondering if someone can point me in the right direction for figuring out if this is the case? Cheers for the assist
If the event runs as an ITS tournament then whatever narrative you want to add on top doesn't matter but if you play multiple times against the same people then maybe the league format will work better? You could also just buy the box for the prizes to support your narrative campaign and use the code to register a separate tournament later...
